Go to Post Being a mentor only requires an open mind and fifty thousand times more responsibility. - Amanda Morrison [more]
Unread 13-11-2006, 19:50
penguain penguain is offline
AKA: Barry Preston
FRC #1997 (Stag Robotics)
penguain is an unknown quantity at this point
C or C++
which programming language is used in the robot for FIRST(FRC)... i see on the web site it says its C.... but my Team coach said it was C++?
some clarity would be helpful
thanks
Unread 13-11-2006, 19:53
thegathering's Avatar
thegathering thegathering is offline
Angry Troll Lurking in the MUD
AKA: Ben
FRC #1885 (Robocats)
thegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to behold
Send a message via AIM to thegathering
Re: C or C++
We use C with an IDE called MPLab by Microchip.
*edit* I wish we could use C++ though, then maybe we'd get some more programmers on our team. C tends to scare them off. (maybe that's MPLab's icky-sticky interface rather than the language itself )
*2006 Champion Rookie All Star Award.
*2 x 2006 Regional Rookie All Star Awards.
Unread 13-11-2006, 20:11
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: C or C++
Its C.
They could always command line compile it. Im sure they would hate that even more.
Unread 13-11-2006, 20:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: C or C++
I don't think an FRC robot program is likely to benefit from object oriented programming in most cases. We're typically not dealing with a lot of objects that need to be created and destroyed that would benefit from a general class, mainly. There would be some benefit from the probable increase in code modularity and code reuse.
Mostly, however, I think objects inherently incur higher overhead costs than simple structures and procedure calls, what with instantiation and all sorts of things. So I don't think you could take advantage of the strengths of object oriented programming without making your code uselessly large.
Unread 13-11-2006, 21:07
AKA: Ben
Re: C or C++
Well, we tried to make our code as object oriented as we could, which ended up working well for our automatically aiming camera/launcher code.
Unread 14-11-2006, 00:21
Re: C or C++
It wasn't C++ code, though, so you didn't have class definitions and a memory manager floating about cluttering things up. You can, of course, still mostly apply object oriented design rules to get more modular, more portable code, but it still won't be C++ code, for good or ill. (Mostly for good)
Unread 13-11-2006, 21:46
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Re: C or C++
The icky interface scared me for a bit. C is an awesome language for embedded systems.
My Blog!
Unread 13-11-2006, 21:53
foote stepped in
AKA: E. Foote
FRC #0868
Re: C or C++
just be thankful you don't have to program it in assembly...
C works terrific for a robots needs, when I'm trying to help the java peoples learn it, i tell them
"object oriented programming with robots would be kinda useless. For example, what would be the point in
Robot868 robot1 = new Robot868(void);
robot1.drive(10.0);
when you could write code that would simply be drive(10.0)? besides, the interface that Kevin supplies us with is alot more useful."
Too bad its not so easy to describe #define, or any other preprocessors to them .
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 14-11-2006, 16:47
♥♣♠♪'s Avatar
♥♣♠♪ ♥♣♠♪ is offline
DemiOmniGod
FRC #1546 (Chaos Inc.)
♥♣♠♪ will become famous soon enough
Re: C or C++
All you have to do is explain what compilation is and everything else should be easy.
Programming && English !mix
Our website
Unread 14-11-2006, 21:00
Umm Errr...
Re: C or C++
I think most of us would agree that we would rather have the flexibility and added features of C++, particularly object oriented-ness.
The problem with C++ is that along with its added features comes added bloat and inefficiency. Unless the architecture and processing power were SUBSTANTIALLY and unnecessarily upgraded, all of the people who keep complaining that C is primitive would be complaining that their code wouldn't run if we upgraded to C++. Memory allocation/deallocation is no small task, especially when handled in software. C++ is good for PCs where functionality is a greater priority over efficiency and there is an abundance of computational power, but not so great for our application. In industry, C is not considered outdated, it is the standard in the world of embedded programming and for good reason. C is sleek and slim.
Heated seats, radios and air conditioning are good to have but race cars don't have them and do just fine without them. Our robots, like race cars are designed minimalistically. There is nothing on a FIRST robot that is not absolutely necessary and that goes for code too.
Any problem that can be solved in C++ can be solved in C. The solution may not be as coder friendly, but chances are it will be smaller and take fewer processor cycles to execute.
1139 Alumni
Unread 14-11-2006, 22:43
Re: C or C++
Why? What particular itch would be scratched by having OO in your robot-programming toolkit?
That's obviously true -- because the first implementation of a C++ compiler was as a preprocessor that produced straight C code. If you want to use C++ to program your robot, just get a copy of the old AT&T Cfront program.
Unread 14-11-2006, 23:09
Re: C or C++
Well it would let you use << instead of printf's. Heck you could overload << operator to output motor values or set the target of a PID loop or other mostly useless but amusing things, I suppose.
Unread 15-11-2006, 08:21
Re: C or C++
I was asking about Object Oriented, not Operator Overloading. My question is this: how would object-oriented programming be useful in programming a FIRST robot?
Modular programming is obviously a good thing, but I don't really see a good use for classes and inheritance and polymorphism and such.
Unread 14-11-2006, 23:17
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: C or C++
It's amazing the misconceptions that have been posted here about the differences between C and C++. C++ code doesn't have to be bloated compared to equivalent C code. When using the advanced features you do have to know what you're doing if you don't want to pay a size or performance penalty.
I used C for years and then moved to C++. Moving back to C was an extreme shock. Having to jump through hoops to do reasonable encapsulation and using funky naming conventions to keep the code organized and readable is a roaring pain. The lack of proper const types is inhibiting.
Some here seem to think that using C++ entails a lot of new and free calls to create and destroy objects. If your C code isn't using a lot of malloc and free calls, there will be no difference. And for a FIRST robot you really don't need any dynamic memory allocation.
C++ is a much better language and with proper use can even produce smaller, faster code than C. Not to mention if the code is properly written, it's easier to understand, maintain, and more robust.
Unread 15-11-2006, 08:13
Gdeaver Gdeaver is offline
FRC #1640
Re: C or C++
I always thought the problem with object oriented languages and microcontrolers was the async nature of OO. In other words OO is terrible for RTOS's.
