Go to Post Once you have a lathe you'll wonder how you ever got through life without one. - Wayne TenBrink [more]
Unread 28-11-2006, 17:23
kokodabear's Avatar
kokodabear kokodabear is offline
HELP!
AKA: Brady
#0686 (Bovine Intervention)
kokodabear is an unknown quantity at this point
Send a message via AIM to kokodabear
Exclamation Cannot Program RC
Today, for training purposes, I tried to program a 2005 RC. I did not modify the code on the RC since the 05 season, and everything seemed to be working beforehand.
The code I attempted to put on the RC was made using:
- MPLAB IDE v7.2
- C18 Compiler v 2.4
- 06 Default Code 21-28-2006
I hit the program button and downloaded the code. However, when it was done downloading, the program light remained orange. I figured this was because the latest default code requires the latest master code, so I then downloaded the newest master code (v11).
At this point, things got weird. The top 2 LEDs (Battery Power, Program State) remained green while the rest of the LEDs went dim, while the OI reported no connection. Reseting the RC did not have an effect, nor did pressing the program button. I tried hitting the program button anyway to see if I could download the user or master code but nothing worked.
I'm assuming the master code did not download correctly, but I'm unable to re-download it. Any suggestions?
Unread 28-11-2006, 18:24
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Cannot Program RC
if programming from another computer doesn't work, try removing it totally from the bot and try again, if not working at this point, id say call or contact IFI it sounds like it may need their love.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 28-11-2006, 19:25
theycallhimtom theycallhimtom is offline
AKA: Tom Conerly
FRC #1540 (The Flaming Chickens)
theycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura abouttheycallhimtom has a spectacular aura about
Send a message via AIM to theycallhimtom Send a message via MSN to theycallhimtom
There is a difference between programming on the 2005 and 2006 RCs. When you compile the code there are some changes (which I forgot) that you need to do to switch between the do. I'm guessing the master code is setup for 2006 not 2005 so that would be your problem. Also you might want to look into your version of IFI loader.
Unread 28-11-2006, 20:21
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Make sure you are re-compiling the 06 code with the libraries for the 05 processor.. or just use the 05 default code..
Unread 29-11-2006, 17:29
kokodabear's Avatar
HELP!
AKA: Brady
I'll try that... once I'm able to re-program the thing.
What effect would removing it from the bot do? I would think that turning off the power would have the same effect.
I think I'm gunna call IFI, but thanks for the help
Gearing That Cannot Overcome Static Friction Madison Technical Discussion 15 03-08-2006 10:23
help: cannot get the picture in the labVIEW program .. (was: need help!! quickly!) liad LabView and Data Acquisition 8 18-01-2006 12:20
Cannot access "double" values chantilly_team Programming 14 06-02-2005 13:39
Cannot place constrain in Inventor Paul Marshall Inventor 9 05-02-2004 05:56
2 Hours Sleep and I cannot bear to see another nut or bolt.. archiver 2001 2 24-06-2002 00:54
