pic: Dual sprocket Dewalt drive
Re: pic: Dual sprocket Dewalt drive
Andy, are you hoping to use this on the 2007 robot? If so, how are you planning on accomplishing the shifting mechanism (this was sort of an unknown when we were playing around with this a few years ago)? I see that there is a little notch in the shifting mechanism... would you like to explain?
Anyways, looks nice, as always. I hope you don't mind if I drop in on a meeting or two over my Christmas vacation. ![]() Last edited by Jaine Perotti : 04-12-2006 at 16:44. |
the dewalts generally are shifted with a servo.
How did you fit the second sprocket?
We are not planning on using the DeWalts next year for the drive. I was playing with the shifter using a servo but pulled it off before I took the robot out in the street.
The sprockets are attached like a sandwich. The outboard sprocket is type A, no hub. The inboard sprocket is type B, with hub. The hub is machined to reduce the distance between the sprockets. Both are piloted on the adapter. Clearance holes are in the first sprocket and tapped holes in the second. Simply run two bolts from the outside. Jaine - stop by anytime, we are using the same general schedule. |
| Dual CIM Dewalt??? | Joe Johnson | Motors | 4 | 30-01-2006 09:49 |
| pic: Dual FP motors through a Dewalt XRP | Andy A. | Robot Showcase | 5 | 18-02-2005 09:07 |
| pic: Dewalt Dual Motor | CD47-Bot | Extra Discussion | 8 | 10-12-2004 20:31 |
| pic: Dual-Speed Drive Module | CD47-Bot | Extra Discussion | 3 | 07-11-2003 13:45 |
| White Paper Discuss: Dual-motor, dual-speed drive transmission design | CD47-Bot | Extra Discussion | 9 | 03-09-2003 10:40 |
