Go to Post Well, John V-Neun still has a little bit of hair. Maybe it'll be an astroturf field? - Amanda Morrison [more]
Unread 07-12-2006, 13:28
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
pic: Team 701 Mecanum Design View 2
Re: pic: Team 701 Mecanum Design View 2
So, you're drilling a hole through a bolt?
Unread 07-12-2006, 13:44
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
2, actually.
Come on Tom, you can't tell me that the Cyberknights haven't done that! (I'm sure GUS has done it.)
BEN
Unread 13-12-2006, 19:27
FRC #0701 (RoboVikes)
Assuming everything fits snugly how are you going to tilt the gearbox forward, the two vertical bolts will move forward when you tilt the tranny down and not line up with the bottom bolt (??) I guess you will oversize the holes in the threaded rod???
Team 701
Unread 06-03-2007, 02:02
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Actually no, you would certainly want to use a piece of shaft and just thread that. It's tedious, I know, but it gives the strength you want with something holding your gearbox.
Salik, I'm thinking both of the shafts would be allowed to rotate, the gearbox should tension nicely if everything is lined up to begin with.
pic: Team 701 Mecanum Design View 1 Doug G Extra Discussion 11 13-12-2006 03:21
pic: Team XBot Mecanum Practice Chassis Fred Sayre Technical Discussion 28 22-11-2006 09:21
701 Design Alekat Robot Showcase 5 01-02-2006 01:40
pic: Team 226 side view CD47-Bot Robot Showcase 8 25-02-2004 16:25
pic: Team 271's Side View CD47-Bot Robot Showcase 1 17-03-2003 18:48
