Go to Post And those who DO know won't talk, even for Krispy Kremes. - DonRotolo [more]
Unread 07-12-2006, 13:49
dfukuba's Avatar
dfukuba dfukuba is offline
Technical Advisor
AKA: Daniel Fukuba
FRC #0008 (Paly Robotics)
dfukuba is just really nicedfukuba is just really nicedfukuba is just really nicedfukuba is just really nice
Send a message via AIM to dfukuba
Drivetrain question (Chessy Poofs)
Alright you guys,
Our team is building a few different drive-trains so we can see which one turns out most suitable. I wanted to know if anyone had anymore information on the Cheesy Poofs drive-train. I was able to find a lot of nice photos they took from 2005. But if you look at this picture;
http://team254.bcp.org/old-site/images/05robot18.jpg
You can see the pillow blocks going into the tubbing. This caught my eye and looked interesting. What is inside? is there anything inside?
If anyone has more detailed photos or maybe a nice explanation, i would greatly appreciate it.
thanks!
-Dan Fukuba
Unread 07-12-2006, 13:56
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Re: Drivetrain question (Chessy Poofs)
Originally Posted by dfukuba
Alright you guys,
thanks!
-Dan Fukuba
There are pillow blocks on each side of the rectangular tubing supporting each wheel's shaft. On the inboard side , there is a cantilevered sprocket, except in the center where there is the gearbox.
The wheels are cantileverd on the outboard side.
--Madison--
...down at the Ozdust!
Unread 07-12-2006, 14:04
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You can see a number of CAD screenshots of this year's drivetrain here
Nothing is inside the tubing itself. It's just two halves of a bearing housing that slide into each other and then ride inside the pocket in the frame. You can see specifically how this works in this image. On the inside of the frame there is a sprocket mounted on the shaft to drive the wheel. The center bearing housing goes into the frame, and then bolts to the actual transmission plate.
2001-2004: Team 100
2006-Present: Team 254
Unread 10-12-2006, 21:21
dfukuba's Avatar
Technical Advisor
AKA: Daniel Fukuba
Re: Drivetrain question (Cheesy Poofs)
Ah okay that is pretty interesting. And it seems that the pillow blocks have a little part for tensioning. Thanks for the help!
Unread 10-12-2006, 23:03
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Here is an actual picture of the 2 halfs. The left one goes on the inside of the frame and slides into the one on the right which is mounted outboard of the frame.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 10-12-2006, 23:15
I noticed that 968 would tighten a bolt in the front of their frame to tighten their chain. How would that bolt interface to the piece pictured above? I don't see a place for the bolt to attach to the machined part.
Austin Schuh
Unread 11-12-2006, 00:24
Rafi Ahmed's Avatar
Rafi Ahmed Rafi Ahmed is offline
Mentor & Alumni
FRC #2522 (Royal Robotics)
Rafi Ahmed has a spectacular aura aboutRafi Ahmed has a spectacular aura about
There is a steel cam that pushes up against one of the edges when it is turned of the inner pillow block which moves the block.
Team 2522 | Mentor
Formerly of Team 22 and Team 4
Unread 11-12-2006, 00:27
Cory's Avatar
AKA: Cory McBride
Originally Posted by raf4far View Post
There is a steel cam that pushes up against one of the edges of the inner shaft which moves the housings.
Only on our robot. As can be seen here
968 tensioned their chains differently. Travis can explain how when he sees this.
2001-2004: Team 100
Unread 11-12-2006, 03:45
Engineering Mentor
FRC #0254
We had an aluminum clevis that bearing housing screw went through. Tightening the bolt would thread the bolt further into the clevis and would in turn pull the bearing housing assemblyy outward, tensioning the chain. The weight is negligible between the two, we just didn't have the time to make the cams.
-Travis Covington
pic: Xbot vs. Cheesy Poofs, Round 2. Madison Robot Showcase 16 27-10-2006 00:18
Cheesy Poofs Chairman's Video Joe Matt Chairman's Award 17 02-05-2005 21:59
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Cheesy Poofs thank everyone archiver 2001 0 24-06-2002 03:21
Cheesy Poofs 4-0 at Regionals archiver 2001 7 24-06-2002 02:40
