CAM2 - Standalone
Hey guys,
Since im new, i brought home the camera to study it. I have been reading the Adobe Reader file and found out that you are able to connect it to the computer. Now, i have everything setup, it knows that its connect BUT, it still trying to connect to the camera. Hmm.. i guess it doesnt work because i do not have the pwm powering it? would that be the problem if u could let me noe if it needs a external power source that be great![]() |
Re: CAM2 - Standalone
Yes. You have to provide power to the CMUCam before it will talk to you
You also need to make sure you have the baud rate set correctly or it will return garbled text. The camera needs at least 5 volts to run.
The CMU cam has a 5V voltage regulator in it. According to the manual "CMU2 requires 6-15 volts of DC power capable of 200mA of current" I have run it at 5v off the RC and it works fine. |
| CMU Cam2 Java app (Help with Labview GUI) | Team 1649 | Programming | 3 | 26-12-2006 14:25 |
| cam2 hight | savage | General Forum | 4 | 21-02-2005 02:12 |
