Go to Post As my daughter said, you used to shut up your robot and send it away from home. Now you just suffocate it. - GaryVoshol [more]
Unread 07-12-2006, 23:01
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
incrementing
HEy Quick Question
If i say..
static int i = 1;
i++;
Then it will increase by 1..... how do i increase by 2... or maybe 3... would it be?
static int i = 1;
i++2;
... maybe? lol i ono talk to me
Great Art is Created; Master Pieces are Stolen
[n00b]Teh_Foxdonut teh_pwnerer795 - CounterStrike:Source
Unread 07-12-2006, 23:07
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
Re: incrementing
Just i = i + 2
i++ is a shortcut, otherwise just use the number you would like to add
Unread 07-12-2006, 23:09
Ari Allyn-Feuer Ari Allyn-Feuer is offline
FRC #0753
Ari Allyn-Feuer is on a distinguished road
Re: incrementing
Originally Posted by teh_pwnerer795
HEy Quick Question
If i say..
static int i = 1;
i++;
static int i = 1;
i++2;
You can use the ordinary mathematical operators in C. The syntax is:
name_of_var = [EXPRESSION]
You can string them together:
var1 = var2 = 3
sets both var1 and var2 to 3.
You can use +, -, *, divide, everything. Please note that with integers, divide just truncates. Also, there are a few little things C does. Like ++ adds one without the equals, -- subtracts without it. varname += n will add the value n to varname. same for -=, *=.
Also, you can use the symbol % for remainder in division, or for modular arithmetic. Like 7%3=1, 56%10=6, 39%17=5.
If you need any more help, ask me. ari.allynfeuer@gmail.com
Ari.
Unread 07-12-2006, 23:19
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Re: incrementing
i++ is shorthand for i = i + 1 since incrementing by one is such a common task in programming. Similarly i-- is the same as i = i -1. If you want to add or subtract something different then you have to use the long version as in i = i + 3.
Not many people realize you can also go ++i and --i which is subtly different. In most cases the end effect is the same but not always. With ++i (prefixed) the value is computed before the expression is evaluated. The postfix version i++ is the opposite where the value is computed AFTER the expression is evaluated. This doesn't make any difference if you just go:
i++;
or
++i;
However if you try:
m = ((++i)*(j++)/5;
i will increment by 1 BEFORE the rest of the expression is evaluated. j will be incremented AFTER the expression is evaluated.
Good luck!
Unread 07-12-2006, 23:33
AKA: !!Mitch!!
FRC #1392
Re: incrementing
i++;
or
++i;
However if you try:
m = ((++i)*(j++)/5;
Good luck!
Awesome.. thanxs for the tip more for my programming knowledge
Unread 08-12-2006, 03:39
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: incrementing
static int i = 1;
i++2;
i++ and its prefix version ++i only add one. There's no way to increment by a different value using this notation.
To add 2 there are two ways to do it.
The "classic" programming construct
i = i + 2;
and
i += 2;
The second version can be more than just a slightly shorter way of writing the expression if you have a non optimizing compiler or one that doesn't optimize very well.
To digress a little and provide some history, there are three ways to add 1 to a variable.
The increment operator in either postfix or prefix form: i++ or ++i
An in place add: i += 1
And the load, add, and assign: i = i + 1
With a non optimizing compiler and a fairly rich native machine instruction set, these three forms will all generate different machine code and some forms will be more efficient. The programmer would chose the form to use based on knowing how the compiler would translate it.
For instance on an Intel x86 chip the increment operator maps directly to the assembly instruction INC so you do the increment in one instruction.
The second form generates machine code that directly adds the number to the variable. It's longer since it first loads 1 into the accumulator and adds that to the variable directly. Two instructions, so not as efficient.
And finally, the third form causes the processor to load the variable i into the accumulator, add 1 to it, and then store the result back into i's memory location. Even more instructions and slower execution.
On processors like the PICs in the IFI controllers the instruction set is much more limited so it's not as likely to make as much difference. Also, modern optimizing compilers will typically find the "best" machine instructions to use. With some you can even tell them to optimize for smaller code size or faster execution. Sometimes, paradoxically, smaller code is also faster.
Unread 08-12-2006, 06:48
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: incrementing
Easiest way to do it is just i+=2 or i=i+2
Unread 08-12-2006, 07:33
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Re: incrementing
you can just do i+=2 or i+=3 not much diff, but hey! it is the same number of keys your pressing.
Unread 08-12-2006, 15:25
Re: incrementing
Originally Posted by TimCraig
i++ and its prefix version ++i only add one. There's no way to increment by a different value using this notation...
Here's something few people know about C: pointer arithmetic scales integers by the size of the type being pointed to. For example, if ptr is a pointer to an int, then ptr++ will add 2 (or whatever the native size of an int is for a particular target). If parr is a pointer to a structure of twelve bytes, parr = parr + 3 will add 36.
But don't abuse this fact. Pointer arithmetic is not necessarily something useful for programming PIC processors to control FRC robots.
Unread 08-12-2006, 16:43
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: incrementing
*chuckle
well yeah theres lots of ways to say it, but it all compiles the same. personally, <operator>= is my favorite. but hey, thats just me.
see you all later... i'll be rockin out to them xm seasonal channels
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 09-12-2006, 23:40
AKA: Tim Craig
Re: incrementing
That's true, however using a pointer that way for general arithmentic and casting it back to an int type would definitely be abusive and the programmer need not apply for a job in my shop.
One place I've used pointer arithmetic along those lines with the PIC is to be able to treat the PWM outputs as an array. Although there the increment in address defaults back to 1.
