Go to Post I see all these people complaining about the FIRST game having perverse penalties for playing defense...then we play without defense, and still people complain. - MrForbes [more]
Unread 11-12-2006, 08:30
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
pic: Vex transmission (bottom view)
Unread 11-12-2006, 08:32
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: pic: Vex transmission (bottom view)
Out of curiosity, why are you using double gears for the gearbox? Is that to reduce the chance of a gear breaking, increase efficiency, or is there a microscopic shifter in there I can't see?
Unread 12-12-2006, 02:48
doukjin's Avatar
doukjin doukjin is offline
FTC 219 Mentor/Coach
AKA: Doug Kim / DJK
FTC #0219 (Wheeler Circuitrunners)
Team Role: Driver
doukjin will become famous soon enoughdoukjin will become famous soon enough
Send a message via AIM to doukjin
microscopic shifter of course
2006 FVC Team 80 Driver
2007 FVC Team 1002 Team Manipulator Designer
GA Regional Inspire Award Winner and 2nd seeded alliance
Unread 12-12-2006, 09:25
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Ha, I wish! I actually just used the double gears for good measure, and also because there was enough room for them without making the design overly complicated. It does make it a little bit stronger, but from my experience nothing would break if it just had 1 gear on each shaft. I actually saw several gears explode at the AZ VEX regional, but they were being put under much more stress than these ones would be.
Unread 12-12-2006, 13:07
Dan_Karol Dan_Karol is offline
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
Dan_Karol has a spectacular aura aboutDan_Karol has a spectacular aura about
Send a message via AIM to Dan_Karol
Redundancy is always a good thing, especially when the breaking strength of the gears are not advertised like in vex. At the Massachusetts regional over at QCC we broke 4 of the small tooth gears on our arm. But my question for you is where is the shaft collar for the motor's axel? Aren’t you afraid of it slipping out at a competition and loosing that side of your drive?
Unread 12-12-2006, 14:34
s_forbes's Avatar
The shafts shouldn't fall out; I roughed up the ends of them so that they don't slip out of the clutches. I've used this method on several other robots, and as long as the shaft isn't getting a bunch of side load it stays in.
And I'm not actually in the competition, I was just playing around with some ideas for the game.
Unread 12-12-2006, 15:13
The Arizona Mentor
AKA: Andrew
Actually, all the strengths are listed here:
http://www.vexlabs.com/vex-robotics-gear-kit.shtml
Thanks for the answer. So with all these Vex gearboxes, when can we expect a contest to see who can build the strongest gearbox? I'll give it to whoever has their Vex robot lift them off the ground.
Unread 13-12-2006, 14:54
Mentor and Coach
AKA: Daniel Karol
FRC #0131 (CHAOS)
O thx!, i spent 2 hours searching for them the other day, guess i looked in the wrong places
2004 - 2012: Team 1100
2013 - ????: Team 131
pic: Team 188 Electronics Board (Bottom) Mr. Lim Extra Discussion 7 02-02-2009 16:52
pic: Team 930's Cart (Bottom) CD47-Bot Extra Discussion 10 31-12-2008 07:15
pic: Bottom view of The Red Dragon redbarron Extra Discussion 27 02-02-2007 10:20
pic: 2 Speed Vex Transmission cire FIRST Tech Challenge 12 20-05-2006 21:14
pic: front view Tim566 Extra Discussion 2 24-03-2006 23:03
