Can not use camera code!!:'(
Hey guys
for some reason when i go to complie the program i get this error Executing: "c:\mcc18\bin\mcc18.exe" -p=18F8722 "camera.c" -fo="camera.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- -nw=2066 -D_FRC_BOARD This version of the compiler supports only the PIC18F8520 processor. this is strange... i am using 7.2v mplab and 2.2v C18... i think i may need 2.4?? |
Re: Can not use camera code!!:'(
"This version of the compiler"????
I think you are right - we have C18 v2.40 Release Notes for MPLAB(r) C18, PICmicro 18Cxx C compiler v2.40 17 November 2004 Last edited by mluckham : 14-12-2006 at 01:10. |
Yes you definitely need version 2.4 of the C18 compiler to use the camera.
| Ethics 101: To re-use or not to re-use? | aaeamdar | General Forum | 87 | 07-12-2006 19:10 |
| Camera code not working.... | DemonYawgmoth | Programming | 5 | 11-02-2006 09:21 |
| Camera Not Responding To Code | itzrobz | Programming | 2 | 05-02-2006 12:47 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
