Go to Post While grandmothers are pretty cool, I would be hesitant in letting them determine what is and is not a robot. - Kellen Hill [more]
Unread 21-12-2006, 22:39
Dylan Gramlich's Avatar
Dylan Gramlich Dylan Gramlich is offline
Christian group in FIRST? Ideas?
FRC #1126 (SparX)
Team Role: Tactician
Dylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond reputeDylan Gramlich has a reputation beyond repute
Send a message via AIM to Dylan Gramlich
pic: Alex Cormier's Vex Teaser
Unread 21-12-2006, 22:44
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Re: pic: Alex Cormier's Vex Teaser
Well, while you didn't ask us to "tear it apart" in this picture, I'll do it anyways.
We found that the VEX chain stretches quite a bit over time. I would recommend putting the chain on the end of your shafts for two reasons.
1) A slack chain will probably run against the balls. Not sure if that'll affect the operation of your hopper.
2) Having the tension in the middle of your shaft will cause the shaft to bend a little easier. We had a hard time keeping our spans narrow (especially with the size of the softballs.) We've noticed that the shafts are bending quite a bit, and aren't really straight anymore. So much for 1/8" steel shaft...
It looks good overall. If you can make it two balls wide, I think you'd be better off. Our base is similarly sized, as 12" wide by 15" long. It turns just fine with 4wd. However, with the size of the big ball, you have to watch out for being tipped from the side by it. We almost took a couple tumbles in some pushing matches to get the atlas ball...
Good luck!
BEN
Unread 21-12-2006, 22:55
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I'm assuming it's a hopper that will pick up balls and then be elevated to the level of the goal and spit them back out (ala many FRC teams in 2000 and 2002).
You may want to make it wider, we've found many times in both FRC and FVC that have margin of error when picking up balls really helps (and additional storage space).
Unread 21-12-2006, 22:57
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
It is just somethings i am working on at home during sesmester breaks.
I will bring the idea to the students and i'll have them make some concepts on paper before i show them those designs and we will use a little bit form both deisgns to make one robot. so what you see here is not final or even close to it. It's just playing around and see what works and what doesn't.
thanks for the advice, i'll take it into account with the next modifications.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 21-12-2006, 23:23
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
this is similar to 1114's design for ball pickup
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 21-12-2006, 23:35
in between teams
AKA: Luke Van Oort
It looks simple and effective, however, I'm still waiting for an FVC robot with a design based on CD in 2000. (Hmmm, VexLabs swerve drive modules are sold in pairs, interesting)
Team 1219: 2009 - Mentor
Unread 21-12-2006, 23:43
Bengineer
Apparently, you'll have to wait until the Championship to see that...
BEN
Unread 22-12-2006, 11:36
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
maybe you could use compressor dampeners on the stand offs
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
pic: Vex Teaser: What's Art been up to lately? artdutra04 Extra Discussion 10 13-01-2007 23:46
pic: RCCR Vex Game Teaser Dylan Gramlich Extra Discussion 22 27-10-2006 05:10
pic: Rah Cha Cha Vex Teaser Alex Cormier Extra Discussion 5 21-09-2006 10:21
pic: [Teaser]: When Vex meets Tetra artdutra04 Extra Discussion 7 18-09-2005 14:31
pic: 111 Teaser (tiny teaser) CD47-Bot Robot Showcase 15 04-03-2003 00:49
