Go to Post ...okay, maybe I have a xkcd addiction - plnyyanks [more]
Unread 24-12-2006, 10:41
CraigHickman
Posts: n/a
pic: 114 CAD idea
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: pic: 114 CAD idea
Its looks nice. However I think the arm might be heavy. Do you have an estimate weight of both the arm and the whole robot?
Unread 24-12-2006, 10:47
Billfred's Avatar
Billfred Billfred is offline
I'm willing to bet it can be slimmed down as well, but I've got to ask the other pressing questions:
1) How would you have it expand or retract?
2) Is the arm designed to tilt, a la 233 or 1251 in 2005?
Unread 24-12-2006, 10:50
CraigHickman
Posts: n/a
The arm tilts, and will extend via cable pulled by a winch like mechanism at the base. As far as the mechanism to do both of these, I haven't added it in as of yet.
Weight on the arm is about 10 pounds.
Unread 24-12-2006, 12:49
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Do you really need box tubing for the whole arm?
In 2005 we had a staged lift almost exactly like that, and it was made of flat stock and angle stock welded together. You could probably save a bit of weight if you do the same.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 24-12-2006, 14:25
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I am having hard time believing that it is only 10 pounds...
1) How long are the pieces?
2) What is the wall thickness (1/16? 1/8?) on the box tubing?
3) Are those L brackets quarter inch thick?
4) How many of those L brackets you got in that design if they are quarter inch thick?
... the reason I am asking these questions is to see if you miscalculated while you were figuring out the weight for the mechanism.
I would jump up and down if I had 100 pounds to work with for a chassis and electronics (assuming your mechanism would be between 10-20 pounds).
Unread 24-12-2006, 18:47
run the trap!!!
Team Role: Human Player
I really hope the game pieces are intertubes too
Any ideas on how you will pick them up? There isn’t a lot of room there for a claw/grabber/(thing).
-Philip J. Fry
Unread 24-12-2006, 19:01
CraigHickman
Posts: n/a
As far as material choice, this is my first time designing a game object manipulator. Up until now, I've been the drive train guy.
The extrusion for the arm is 1x1 with 1/6th inch wall, at 24 inches long, and the sliders/brackety things are made of delrin, and are 1/4inch thick. I'm probably going to make the thing smaller, but with the grabber I play to design onto the end... I might need to make it thicker. This grabber should be able to passively "slurp" up about 4-5 inner tubes at a time, and then spit them out onto a post. Now all of this is speculative of what I think the game will be.
pic: 114 drive base CAD CraigHickman Extra Discussion 4 15-12-2006 00:31
pic: 114 Coaxial Final CAD CraigHickman Extra Discussion 3 01-07-2006 22:45
pic: 114: Stripped! CraigHickman Robot Showcase 5 04-04-2006 23:49
pic: 114 wheels CraigHickman Robot Showcase 12 31-01-2006 15:50
pic: 114 inventor robot CD47-Bot Robot Showcase 15 02-02-2004 19:52
