Go to Post When was the last time you heard of someone on their death bed talking about a great movie they saw? I think it far more likely to hear of their accomplishments, something they did to make things better. Well that's what FIRST is all about. - DougHogg [more]
Unread 05-01-2007, 22:22
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
pic: 6 Wheel Drive Chasis
Unread 05-01-2007, 22:24
Aren_Hill's Avatar
Build Nifty Things
Re: pic: 6 Wheel Drive Chasis
1/8inch wall is plenty thick for the upper structure i may even suggest 1/16th wall but only if you plan on bumpers. And as far as the omnis go i'd play with it once its done it'll be easy to switch them out.
A guy who likes robots.
Unread 05-01-2007, 22:30
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is online now
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Why is the footprint so short? Couldn't you move the front and back wheels out more to keep it from rocking back and forth whenever you drive and stop?
Also, I like how you pre-cheesed the top of the frame. It's nice to start early so you aren't scrambling at the end.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 05-01-2007, 22:36
AJ R's Avatar
RoboGeek
Quote: Why is the footprint so short? Couldn't you move the front and back wheels out more to keep it from rocking back and forth whenever you drive and stop?
Yes, a longer wheel base would be better, but being a rookie this past year, my inventor skills are not the best and did not know how to change it when it was all done.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
Unread 05-01-2007, 22:37
run the trap!!!
Team Role: Human Player
hmmm... 11 hrs. to build and test your prototype. Better hurry!
How are you running the chains? Are all six wheels powered, or are you just powering the center wheels with two CIMs each?
I seriously doubt it will weigh 35 lbs; I estimate between 45-50 lbs., which isn't bad.
Nice work
-Philip J. Fry
Unread 06-01-2007, 08:49
AJ R's Avatar
RoboGeek
Nice work
One of the motors will drive the traction wheel on the end. The other motor will drive the center traction wheel and the omni wheel.
That weighed 35 pounds, but that is without chains, sprockkets, and the iproperties are set to default on the motors. 45 - 50 pounds is proably closer.
AJ
pic: KitBot 4 CIM 2 Wheel Drive Chasis: Side Vince Extra Discussion 6 09-01-2008 19:17
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Omni Wheel Drive -- Top Richard Wallace Extra Discussion 4 05-12-2005 18:55
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: 6 wheel drive train pick CD47-Bot Robot Showcase 3 14-04-2004 07:10
