Go to Post It’s not that we don’t have the time to teach first principals; it’s more that we (FIRST) don’t need to. - Jack Jones [more]
Unread 08-01-2007, 17:19
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Chassis Clearance
Just going to ask about this one in a new thread. How high off the ground do you expect most robots will be? Because most other competitions, they are as low as possible, but this competition involves robots possibly lifting from underneath your robot. Any comments? Maybe even how high your robot will be??
Unread 08-01-2007, 17:21
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Re: Chassis Clearance
Im pretty sure we won't be more than 1 inch, and perhaps as low as possible. The plan at this point certainly seems to include leaving one side of our wheel exposed for climbing ramps however.
Zoheb N Zoheb N is offline
Captain
FRC #0118 (Robonauts)
Zoheb N is just really niceZoheb N is just really niceZoheb N is just really niceZoheb N is just really nice
Send a message via AIM to Zoheb N
Yes it is important to be higher off the ground in order to be lifted up, but if you are using standard bumpers they have to be 2.5" above the ground which limits how high up your robot can actually be.. Our team is not worried about climbing another robot so we are still going to be close to the ground
2004 Lone Star Engineering Inspiration
2005 Denver Regional Winner
2005 Denver Radio Shack Innovation in Control Winner
2005 Lone Star General Motors Industrial Design Winner
2005 Lone Star Regional Winner
2005 Lone Star Regional Chairman's Winner
Unread 08-01-2007, 17:28
FRC #1360
I see. Thanks for the input. I suppose our design will have to be altered slightly, for the lower robots. Then again robots can drive on to us. hmmm.. Lots to ponder still.
Unread 08-01-2007, 17:31
Captain
no problem.. but you still have to think that you only have 2 inputs right now.. there will be many teams though that will focus on being able to get up a ramp or be lifted
Unread 08-01-2007, 17:33
Ericgehrken's Avatar
Ericgehrken Ericgehrken is offline
AKA: 3 Teams in 3 Seasons
FRC #0190 (Gompei and the Herd)
Ericgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud ofEricgehrken has much to be proud of
Send a message via AIM to Ericgehrken Send a message via Yahoo to Ericgehrken
If you want to be lifted make a handle or high side or two, other than that if you want to be purely offensive on the rack and nothing else then a low robot and the same goes if you are going to be the one doing the lifting. But also have a back up plan in case all of your alliance for one match is going to be purely offensive or defensive, lift or be lifted. Have someone on the alliance commit to offense or defense prior to the match so the other alliance doesn't have open scoring oppurtunities.
Team 3125
GHAMAS FIRST Robotics
Team President and Founder
2010-
2010 Suffield Shakedown Winner Thanks 178 and 177
2010 WPI Regional Rookie All Star
2010 WPI Dean's List Finalist
Team 195 Member 2007-2009
2007 CT Regional Winner Thanks to 1124 and 558
2008 FIRST Presidents Circle Winner
2009 Suffield Shakedown Winner thanks to 126 and 1124
Unread 08-01-2007, 17:39
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
A low side may actually be preferable for lifting (assuming the lift can still fit beneath it). The higher the side, the higher the lift has to travel (and the greater amount of its maximum range) before it contact and begins to lift the actual robot.
For example. If a lift is designed to go 5" high, but the bottom of the robot's frame is 3" high, the bottom of the robot's wheels will only be 2" high when the lift is fully raised.
Unread 08-01-2007, 18:02
FRC #1360
yeah yeah that is true we thought about that. Let hope we get some but not too much clearance lol
Minimum Clearance? Cyberguy34000 General Forum 9 10-01-2006 11:13
Chassis? jakey Kit & Additional Hardware 1 09-01-2006 15:10
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
Victor Muffin Fans - Height Clearance? Mr. Lim Electrical 4 28-01-2005 15:32
