Go to Post We're not here to build robots. We're here to build students. - GreyingJay [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-01-2007, 18:44
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Battery terminals?
We were about to attach our cables to the battery, and we realized that there are no brackets or terminals to put the cables into other than what's on the battery. I didn't see them in the kit, and the inventory is missing a bunch of things anyways.
What should we do about this? Did some sort of terminal come with the kit?
Unread 08-01-2007, 19:20
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: Battery terminals?
We use something like these and then bolt them to the battery. That keeps them nice and tightly connector and they wount come off.
Unread 08-01-2007, 20:26
ntroup's Avatar
ntroup ntroup is offline
WildStang!
None #0111 (Wildstang)
ntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud ofntroup has much to be proud of
If you look at <R57>, you will see that there are lugs included:
The APP connector must be attached to the battery with either the copper lugs provided in
the FCI Burndy Bag or appropriate crimp-on lug connectors.
You can see a picture of these terminals on page 16 of the KOP_Checklist_RevB.pdf (KOP Checklist), under 'Terminal Lugs - 6-16 ga solderless lugs'.
These are different from the previous year's SLU lugs, but <R57> seems to imply that any appropriate 6 AWG connector can be used. I know that SLU lugs can be found at Home Depot.
-Nate
Unread 08-01-2007, 20:28
Team 2021 Captain
AKA: Chris Davidson
Yes those are way to small. I meant just to show the shape of what we were using (i forget the the correct name for them).
Unread 08-01-2007, 21:57
geeknerd99's Avatar
Fire Hazard
AKA: Daniel Lin
Never mind. I found them. They were in a "conspicuous place".
A cheap resource for parts, (terminals, wire, & Bimba pistons $40.00) RudimentaryPeni General Forum 1 04-01-2007 14:23
Which Terminals? BrittanyV Electrical 10 08-02-2006 20:53
**FIRST EMAIL**/Rule R48 and SLU-70 Copper Terminals Information Rich Wong FIRST E-Mail Blast Archive 2 29-03-2005 17:20
a word of advice when wiring or rewiring motors with solderless terminals pryoplasm Electrical 12 06-04-2004 11:04
Power Terminals LeadRiccardoT Technical Discussion 5 08-02-2003 11:28
