Main Power Terminal Blocks?
I've been laying out some diagrams for the electrical on this year's robot, and the only components that I haven't been familiar with are the new terminal blocks.
These are the modular square boxes that are intended to be attached to a supplied rail. On FIRST's supplied diagram, they are wired between the main breaker/switch and all of the breaker panels and components. I've never used terminal strips like this, I've just wired directly from the positive output on the main switch to the positive input on the component boards, and then used a separate terminal block to return on the negatives to. So really, my question is, does anyone know if these terminal blocks have to be wired to the positive side of the circuit out of the main breaker? Thanks. -Kevin |
Re: Main Power Terminal Blocks?
The power distrubution block is not required by the rules. But, if you are using more than one circuit breaker panel, it would be good wiring practice.
I think it is required. See <R57>.
I also intepret <R57> to mean that the power distribution blocks must be used:
The power distribution block must be directly connected to the APP connector and main 120-amp circuit breaker. No other loads may be connected to the main 120-amp circuit breaker. |
I don't mean to be un-gracious, but what is the point for this new power distribution block? It is taking up a great deal more space and weight. The Maxi fuse block is designed to take like 4 or maybe even two gauge wire. The other panels have big enough lugs to take a terminal for 6 gauge wire. In the past, we would always run 6 gauge wire off the breaker to every panel. Why this intermediate thing? To me, it is like driving from Los Angeles to San Francisco by passing through Wyoming. Is there a good reason for it that I'm not seeing? If not, can we rally for a rule change so it isn't required?
Okay, thanks for the info. I must have looked right over <R57> last night.
I agree though, that this seems to be less of a help than a hindrance... I'm gonna have to sketch my diagram out again, taking into account using a bit more large gauge wiring to fit this block... |
#7
That is exactly what I have been trying to say. It is MUCH more weight and less practical from my knowledge. Can a controls mentor please explain the function of a power block I do not completely understand. Pavan. |
#8
Honestly they are completely useless. From what i know what you always did is still allowed and is not a wrong way of doing it. These blocks are probably just a way for making the electronics look nicer.
#9
I beleive its leagal to use last years power distribution block (altho i havent gotten all the way through the robot section). DIN Rails do add weight but adds a nice organization to your electronics. I do agree it does seem kinda redundant, we found out we will need more negative blocks then the amount we were given and much less positive as we are just using breaker panels for all of our victors, spikes, and the RC.
#10
all the fuse panels are the exact same ones from last years, the power distribution box last year wasnt a DIN Rail but it was essentially the same thing just made of a solid block of plastic.
#12
<R57> The 12V battery, the main 120-amp circuit breaker, the power distribution block, and circuit breaker distribution panels must be connected as shown in the 2007 Power Distribution Diagram. In particular: The battery must be connected to the ROBOT power system through the use of the Anderson Power Products (APP) connector. The APP connector must be attached to the battery with either the copper lugs provided in the FCI Burndy Bag or appropriate crimp-on lug connectors. The battery terminals and the connecting lugs must be insulated with shrink tubing and/orelectrical tape. The main 120-amp circuit breaker must be directly connected to the hot (+) leg of the ROBOT-side APP connector. Only one 120 amp main circuit breaker is allowed. This breaker must not be bypassed. The power distribution block must be directly connected to the APP connector and main 120-amp circuit breaker. No other loads may be connected to the main 120-amp circuit breaker. All circuit breaker distribution panels must be connected directly to the power distribution block. No intermediate connections are permitted. The rules are also supplemented by the Tips and Guidelines and the robot wiring diagram all available on the first website here...http://www.usfirst.org/community/frc...nt.aspx?id=452 Last edited by Al Skierkiewicz : 30-01-2007 at 21:18. |
#13
But I do like the power blocks, they make me feel better about offering some protection in case the small wires from the 120 amp breaker to the individual fuse panels accidently shorted. I noticed that the wiring on last years robot offered no protection for certain types of wiring problems, and I think the new distribution block could make it safer. (I'm an ME, not an EE, so maybe someone could tell me if I'm on the right track?) Last edited by MrForbes : 12-01-2007 at 09:27. |
#14
Thanks guys. I stand corrected.
#15
Guys,
As much as these rail mounted blocks add weight and space, they are standard equipment in most modern electrical installations. Be sure to use the jumper accessory to connect all of the positive blocks together and all of the negative blocks together. These blocks will take #6 wire and I recommend using only #6 to feed the 40 amp Maxi block. It is best to strip back 1-1/2" of insulation and then fold over the strands, twice, so that they fill the entry hole in the Maxi block. This will give you a reliable connection that will not loosen over time. Please watch the team updates for a change on these though. I feel there is an error in the electrical diagram as far as the negative battery side wiring is concerned. Negative lead wiring should follow the same distribution as the positive lead wiring, i.e. all black wiring should return to the DIN blocks, not a common point. Remember all current flowing out of the battery on the red wire, returns to the battery through the black wire. |
| Terminal Blocks in Kit of Parts? | Mark Pierce | Electrical | 13 | 24-01-2007 00:37 |
| pic: Shaft Drive Bearing Blocks | MAteo9944 | Extra Discussion | 25 | 01-01-2007 11:22 |
| [OCCRA]: Pillow Blocks? | Fizzix | OCCRA Q&A | 1 | 12-10-2004 20:57 |
| Power Terminal Block Model | Ed Sparks | Inventor | 1 | 11-02-2004 06:55 |
| pillow blocks | Jacqui Sutton | Kit & Additional Hardware | 1 | 11-01-2003 10:43 |
