Go to Post You might want to read...the Manual very carefully. . - dlavery [more]
Unread 10-01-2007, 09:00
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Download easyC PRO & 2007 Kickoff Code
Download easyC PRO
IF you don't get a CD-KEY today please e-mail us at
FRCRegistration@intelitek.com
please include the teams primary contact name or e-mail address.
http://www.intelitekdownloads.com/easyCPRO/
New in easyC Pro
The easyC for Vex and FRC applications are now integrated into one package.
Switch between robot controllers on the fly FRC 2004-2007 and VEX.
Create your own Source Files, and type freely with the new syntax highlighting new C text editor.
Drag function blocks into the C Code editor files to generate syntax correct code.
Convert Block Functions to raw C Code.
New smart dialog boxes that display only the available ports and appropriate variable types.
Write a Robot Map, and use it to help you remember how your robot is configured.
Edit the Robot Map from the new Online Window.
Link PWM sliders in the new Online Window.
Customize your own dashboard or feedback display with the Graphic Display Window.
Use Switch/Case Blocks to make programming a little easier.
Interrupt Watcher Block checks an interrupt port for a state change.
Check for updates feature that automatically checks the internet for new software features.
New smarter open project dialog.
Simpler to use save features.
Automatic alphabetic ordering of user functions.
New Hotkeys, including Cutting and Copying from the Block Programming Window.
Revised FRC and Vex Libraries with the WPI Library functions built in.
MCC18 Compiler installs automatically into the easyC file structure.
Unread 24-01-2008, 09:15
Kingofl337's Avatar
AKA: Adam
Re: Download easyC PRO & 2007 Kickoff Code
easyC Pro 3.0.1.9
- Vista Compatible
- Terminal Window Logging Feature
WPILIB Port of 2007 Kickoff Code. Kingofl337 Programming 2 16-01-2007 13:50
Additional easyC Pro License Dung H Cao Programming 2 10-01-2007 14:45
pic: easyC PRO at work! Jessica Boucher Extra Discussion 12 14-12-2006 15:25
Kickoff easyC workshop integrated into EasyC help file Dan Larochelle Programming 0 11-01-2006 06:12
