Searching the new gear motor PDF
Hello all,
We've search for the instructions - how to build the new gear motor. We will be glad to see some comments, Thanks, Team #1690 |
Re: Searching the new gear motor PDF
Could you please be a little more specific as to which gearbox (or motor?) you are refering to?
All of the motor data can be found on the FIRST website, under the "Tips and Good Practices" document. Information on the Banebot planetary transmissions can be found on the Banebots.com website. BEN |
we got in the kits new gear (not like the last year)
we didn't find any PDF or outher instructions how to connect between the gear box and the CIM motor. what we are asking if somone have a PDF that describe how to implement this thing. tnx |
Instructions for mounting the small (2.5") CIM motor to the 56mm Banebot gearbox can be found in the cardboard box that the gearbox is packed in. If that has been lost already, you can probably get Banebot.com to email you the instructions. (Or, if someone here wants to scan it and send it. I don't have it here in front of me.)
Good luck, BEN |
| Coupling the drill motor with out the 15 tooth gear | Chopper_Dave | Motors | 1 | 17-01-2004 01:06 |
| motor high gear/low gear switch... | archiver | 2001 | 6 | 23-06-2002 23:50 |
| Specs on the gear of the fisher price motor | archiver | 2000 | 0 | 23-06-2002 23:23 |
| What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. | Robb Gerber | Motors | 2 | 23-01-2002 08:58 |
| Gear for the black motor | Kirk | Motors | 5 | 11-01-2002 15:15 |
