Welded Aluminium?
From what I read, the arena is made from a platform of "Carpted welded aluminium".
What exactly is welded aluminium(and if you can, how can it affect the robot)? |
Re: Welded Aluminium?
where'd you read that?
I would assume that the game components this year are welded together rather than bolted? Welded aluminum is just that. Welded aluminum. It can be done but it's difficult because of the consistency of the aluminum at such high temperature or something like that. As for your concerns about the effects on the robot-- What are your thoughts on this, so people can put some information out there. |
The walls of the arena are constructed of welded aluminum, and the playing surface is covered with carpet.
You only need to worry about the carpet surface, the welded aluminum is not part of the playing field itself, it is only used to make the arena walls, and rack. |
welcome to the wonders of tig welding my friend
What exactly is that carpet made of?
????????? Carpet is just Carpet lol..... But seriously the carpet in some of your class rooms would be very similar.
#7
You can also MIG Weld Aluminium> Tig is better though.
#9
Do you think that the carpet is the really flat carpet that is in schools or carpet that is similar to carpet in homes.
#10
It's a low-pile, commercial carpet. More like you find in schools than in most homes.
#11
Just to close the loop, the carpet is either nylon or some other long-chain polymer. It's not wool.
| Welded Frame Horror Stories | Andrew Blair | Technical Discussion | 45 | 07-10-2006 10:01 |
| Welded Box Tube | tenfour | General Forum | 5 | 27-01-2004 18:54 |
| Thickness of aluminium bars | Randy_Ai | Technical Discussion | 1 | 04-02-2002 20:09 |
| Aluminium Clarification 10-10-01 | Mike Martus | OCCRA | 3 | 18-10-2001 07:55 |
| Aluminium Clarification | Mike Martus | Off-Season Events | 2 | 11-10-2001 10:17 |
