Tracks or Wheels?
Has anyone used tracks before? If so can I please have some help finding the equipment for that. thanks!
Re: Tracks or Wheels?
Team 195 used tracks for the past few years and now their quality has decreased and we are now going to use a six wheel design because of the lack of reliability of tracks.
My understanding is that tracks, while great for stability, are not so good on turning and drain the battery pretty quickly when making a lot of turns. If you'd like to pursue it, I think most teams use belts from McMaster-Carr for their treads.
Last year we 'simply used' (hah!) a four-wheeled system with two of the IFI traction wheels chained to the kitbot transmission -- it worked great at school on the gym floor, but when we went to the Rochester Rally (thanks again, 1511! You rock!) we found that we had so much traction we couldn't turn, and had to do a big re-design.
I can imagine that tracks could easily experience a similar problem. Patrick Freivald -- Team 1551 |
365 had tracks on their '05 bot, look on their site for pics.
Look through the FIRST Mechanism Library to get some ideas. Good luck.
#7
BRECOFlex is a fairly commonly used vendor by FIRST teams for tank treads, check out their website here http://www.brecoflex.com/
Heres a pic from team 195's '04 robot which incorporated modular track assemblies LINK |
#8
The trick with tracks, especially when it comes to turning is to make sure there is a slight pivot point at about the middle of your track setup. It allows for much smoother turning.
Team 703 has used tracks for several years now and the only problem we ever run into is breaking the track. We've improved upon the system to help prevent this, however this year we're working on a totally revolutionary drive system. I'll probably post some pictures after the build season, as it is currently "Top Secret". ![]() |
#9
well i wouldnt consider using treads for your robot because of reliability issues, and when you make a turn theres a chance of the tracks slipping off, but if you already have that design in mind, it would probably be a good idea to use belts other than treads, and theres always the issue of draining the battery with treads.
#11
Naw, you wanna talk draining batteries, last year we had all 6 CIM motors on our drive train! That thing had power but changing the batteries after every match was a must!
You want a hint? Ok, fine this is all I'm giving you... Remember how I said breaking treads was a problem for us? Well we've found a way to create a drive system that simulates the effects and advantages of treads without the possibility of breaking or falling off like a tread. Feel free to post an guesses you may have. ![]() |
#12
Okay, seriously, my vote goes with wheels over tracks for this year's competition. Every team that I have seen with a tracked robot ( except 753 in 2004...) have a very difficult time turning from all the lateral friction. Wheels are easy to set up and easy to design around, which is why we'll be going that way this year. Last edited by Gabe : 12-01-2007 at 00:30. |
#13
A poll would be nice here. |
#14
I think there may still be a misperception about treads here, last year we used treads and we were probably one of the most agile robots on the playing field! Not all track systems are bad, you just have to figure out how to optimize them to make them functional, just about anything you can do with a wheel design you can do with a track design (With the exception of Omniwheels), plus get the added traction and pushing power.
![]() Oh, and sorry Gabe but no Omnitracks for us. We're trying to keep as close to the standard track system as possible.![]() Last edited by cbale2000 : 12-01-2007 at 12:08. |
#15
Well it would seem one of our team members has gone and spoiled the suprise for ya, if you want to see our prototype drive system for 2007, click the following link:
http://www.chiefdelphi.com/media/photos/26312 ![]() |
| do tracks and wheels together make a better robot? | gondorf | Rumor Mill | 31 | 16-01-2006 16:06 |
| Tank tracks vs. Wheels | MBosompra | Technical Discussion | 28 | 16-01-2004 23:31 |
| Where Can I Get Some Wheels Or Tank Tracks? | Alex Cormier | Kit & Additional Hardware | 5 | 13-01-2003 22:58 |
| Tracks | archiver | 2001 | 2 | 23-06-2002 22:59 |
| Beatty tracks | JamesJones | Technical Discussion | 24 | 11-04-2002 13:33 |
