Go to Post Life is more fun if you take some risks every so often. - Andy Baker [more]
Unread 12-01-2007, 09:18
Lablabla Lablabla is offline
AKA: Carmel Barak
FRC #1957 (LighTeam)
Lablabla is an unknown quantity at this point
CMU2Cam Degrees & more
Hi,
I'm Using the streamlined version downloaded for kevin.org/frc
Is there a way to find out the degrees the pan and tilt are in relation to the horizontal and vertical zeros? (i.e camera looking straight forward)
Plus, the zip file downloaded contains everything, the user_routines.c and all that. should i use this as the default code for 2007 and add my autonomous mode and joy controls and all that to that files? or is there a way to add the camera thingies to the 2007 Default code?
Thanks,
Carmel
LighTeam #1957
2006 GM/Technion Israel Regional Finalist (Robot: W.Bob)
Attending: Israel GM\Technion Regional (Robot: Laika)
Unread 12-01-2007, 09:24
itsme itsme is offline
FRC #2217 (FOMH)
itsme is an unknown quantity at this point
Re: CMU2Cam Degrees & more
Well, I can answer only your first question because I am programing in easyC and I don't know MPlabs as well.
for calculating the degrees you need to do the following:
1 degree=Tilt_range/Number_of_PWM
same thing for the pan.
The tilt range is the range of degrees the tilt/pan server can turn.
Number of PWM is 256 (0...255).
Last edited by itsme : 12-01-2007 at 09:57. Reason: changed ratio to range, ratio- wrong word
Unread 12-01-2007, 09:29
AKA: Carmel Barak
Thanks alot for that,
How can I find out the Tilt/Pan Ratio?
LighTeam #1957
Unread 12-01-2007, 09:33
FRC #2217 (FOMH)
you need to see the the documentation about your servo, see how much it can turn in degrees.
Oh, and remember when calculating this way: the starting position (the middle of the range) is half of the ratio. For example: if the ratio is 180, then 1 degree equals about 0.7 PWM, and the starting position is in the middle, witch is 90 degrees, witch is about 127 PWM
Unread 12-01-2007, 09:36
AKA: Carmel Barak
It's the servos we recieved from FIRST, we didn't get any docs with it
LighTeam #1957
Unread 12-01-2007, 09:52
FRC #2217 (FOMH)
To tell you the truth I'm not sure either. I can't find any documentations for this, no place writes how much degrees it has. So please someone answer our common question: how much degrees does it turn?
Unread 12-01-2007, 12:54
JSonntag JSonntag is offline
FRC #0486 (Positronic Panthers)
JSonntag is on a distinguished road
Send a message via AIM to JSonntag
It has a rotation of approximately 90 degrees
http://www.servocity.com/html/hs-322...rd_deluxe.html
Unread 12-01-2007, 18:19
FRC #2217 (FOMH)
So this means that each PWM is 256/90=2.8444... degrees.
And each degree is 90/256=0.3515625 degrees.
:::EDIT:::
It's not 90 degrees for sure, you can buy one with 180 degrees and one with 360 degrees.
So can anybody tell how much degrees it is in the FIRST kit of parts?
Unread 12-01-2007, 18:20
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Or, you can always drive the servo to 0, mark its position, drive it 255, mark its position, and then bust out a protractor.
We did a lot of testing to find the camera field of view and servo ranges in 2005. If I find them later, I will post them, although they may not be exactly the same.
Unread 13-01-2007, 05:02
TEAM1949 TEAM1949 is offline
FRC #1949
TEAM1949 is an unknown quantity at this point
http://www.acroname.com/robotics/inf.../mod322hd.html
look at 'step 4', first two lines
more than 180:
http://www.phidgetsusa.com/forums/ar...php?t-553.html
Unread 29-01-2007, 12:02
jdejoannis jdejoannis is offline
FRC #1845
jdejoannis will become famous soon enoughjdejoannis will become famous soon enough
How do you drive the servos? This would be very useful for us to debug something.
Jason
Unread 29-01-2007, 13:47
Donut Donut is online now
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Originally Posted by Lablabla View Post
Hi,
In Kevin's code he lists the degrees for each range if using the pan/tilt mechanism for FIRST in tracking.h (for example, the pan servo goes from 0 to 248, and has a total range of 130 degrees). To determine the value your 0's are at, you will have to manually control the camera until it is in the position you want to be considered "center".
The servos are driven with standard pwms, so instead of having the camera code create the pan & tilt pwms, have a joystick control the value of the pwm. Comment out servo_track() so the camera has no control of the servos, then do pwm01 = p1_y (with whatever pwms and joystick you want to use inserted there).
Unread 29-01-2007, 19:50
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Jason
If you're using the "bells & whistles" camera code, you can step the servos to any value using the interactive PWM sub-menu found in the main tracking menu.
-Kevin
Kevin Watson
http://kevin.org
Servo Values to Degrees... How? mogunus Programming 16 11-04-2007 02:03
engineering degrees sciguy125 Career 18 17-03-2006 23:44
Turn 90 Degrees Mike Math and Science 16 05-12-2004 22:22
More Pictures & Movies of Team 121 Kyle Fenton Robot Showcase 9 18-02-2003 23:51
TRADE ITEMS--EXCLUSIVE--MOE'S SIGNED SOCKS & MORE archiver 1999 2 23-06-2002 22:37
