Go to Post If only we could have Week 6 urgency every week. - Gray Adams [more]
Unread 13-01-2007, 22:15
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Question Shifting transmissions: servo or pneumatics?
A couple quick questions:
What are the advantages of using pneumatics vs. servos to shift the Dewault transmissions?
Do the Dewaults shift optimally without slowing down or cutting power to the motors (however briefly)?
Thanks in advance,
Robinson
Unread 15-01-2007, 19:23
AKA: Robinson Levin
Re: Shifting transmissions: servo or pneumatics?
Anybody?
Unread 15-01-2007, 19:31
agndoggieboi's Avatar
agndoggieboi agndoggieboi is offline
CpT. cOMmANdo
AKA: Snoogie
FRC #0368 (Kika Mana (Tiger Power))
Team Role: Mascot
agndoggieboi is an unknown quantity at this point
Send a message via AIM to agndoggieboi Send a message via Yahoo to agndoggieboi
our team suggest using a pneumatic shifter than a servo simply because the servo takes to much time to shift as for the pneumatic its a lot quicker
but most it depends on what your aiming for your robot design
if at first u dont succeed...bash it till u do!!!
Unread 15-01-2007, 19:37
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I don't believe you could utilize all 3 speeds on a DeWalt if you use pneumatics (as FIRST pneumatic pistons can only be extended or retracted, not halfway). For that reason, I would suggest using servos.
Unread 15-01-2007, 19:40
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
From years of rc car racing experience, go with pneumatics, servos strip easy.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 15-01-2007, 21:52
DonRotolo's Avatar
Back to humble
FRC #0832
Not exactly. Using what I wrote about here you CAN position a pneumatic cylinder at some place other than the end points - but note that this can be unreliable (especially when the load is variable, but that's not the case here) and doing so does require some care to make it work properly.
But if I were to implement a shifter, I would use a servo, no question. Far more controllable, lighter (especially if no other pneumatics are used) and more flexible.
Don
Unread 15-01-2007, 20:47
robotguru1717's Avatar
robotguru1717 robotguru1717 is offline
AKA: Martin Cacan
FRC #1717 (D'Penguineers)
robotguru1717 will become famous soon enoughrobotguru1717 will become famous soon enough
i dont think the time delay is that big of a problem. its like 1/4 of a second of so for pneumatics and maybe 1/2-3/4 second for servos and servos in my oppinion are a lot easier to use.
Quote of 2007: "That nub looks cattywampus" -Amir Abo-Shaeer
(fyi there were about 50 nubs on the robot)
Team 1717: D'Penguineers
2008: LA-Regional Winner
2008: SD-Regional Winner
2008: SD-Delphi "Driving Tomorrow's Technology" Award
2007: LA-Semi Finalist
2007: SD-Finalist
2007: SD-Imagery Award
2006: Phoenix Semi-Finalist
2006: Phoenix Regional-Rookie Inspiration Award
2006: LA-Rookie All-Star Award
Unread 15-01-2007, 20:49
amos229's Avatar
Retired chicken man
AKA: amouse
But if the servo strips then you are stuck in a gear for the whole game.
Unread 15-01-2007, 21:46
AKA: Robinson Levin
It would seem to me that pneumatics would be much quicker than a quarter second. It's a tiny piston. Then again, the servos seem to move very quickly as well. But at the same time, they seem weaker and more likely to break.
What about shifting while driving quickly/pushing? Will the Dewaults hold up? Or should I quickly cut power to the motors in software (~1/40th of a second, not really enough to slow the robot) before I shift?
Thanks again,
Robinson
paper: Servo Vs. Pneumatic Shifting GMAdan Extra Discussion 1 04-12-2006 11:48
[OCCRA]: Shifting???? Josh Murphy OCCRA Q&A 1 19-09-2006 11:43
Servo shifter for AndyMark transmissions Robby Technical Discussion 3 17-01-2006 01:41
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
Looking for pictures of shifting transmissions that slide gears sanddrag Technical Discussion 3 23-12-2004 07:41
