Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 14-01-2007, 22:15
Michael Hill's Avatar
Negatives in Binary
I'm reading a book on Fortran 90/95 right now, and I was wondering, in general math, how would you go about making a binary number negative without a given bit length? For example, how would I know 1110111101 was -67 rather than 957? I remember something about the leftmost bit being 1, it's negative, and if it's 0, it's positive. But how would I know if 1011 is 11 or -5?
Unread 14-01-2007, 22:25
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: Negatives in Binary
Yes, when the "high order" bit is on it is a negative number, but it doesn't have to be. It depends on your code and what you wish to do with the value or how you wish to treat it.
As for a given bit length it is always in terms of the field type. a byte = 8 bits with high bit as sign bit, a word = 16 bits again high bit is the sign bit, and so on.
I hope this helps.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 14-01-2007, 22:29
So the biggest and smallest numbers allowed in a byte are 255 and -256? what would I do if I wanted to convert the number 3485 to binary?
Unread 14-01-2007, 22:30
something something is offline
FRC #1438
something is an unknown quantity at this point
A signed 4-bit value would only be able to represent values from 4 to -4. Check out two's complement on wikipedia for more info on binary representations of negative numbers.
Unread 14-01-2007, 22:33
OOH! so a number 8 bits long will indicate if it is negative or positive by the left-most bit? so by default a number is 8 bits?
Unread 14-01-2007, 22:48
Phalanx's Avatar
In essence yes.
For a one byte field the value can be 0-255 if unsigned, or between -127 to +127 if signed.
255 = 1111 1111 (unsigned)
127 = 0111 1111 (unsigned)
-127 = 1111 1111 (signed)
+127 = 0111 1111 (signed)
Again it is about how your code wishes to deal with the field as a signed or unsigned value.
Unread 14-01-2007, 23:06
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
Originally Posted by Phalanx View Post
In essence yes.
I think that in most cases (maybe it's different in fortran?), the value -127 would be represented by "1000 0001", using two's complement, which is the most common way to represent negative numbers. It's calculated by changing each 1 to a 0 and each 0 to a 1, and then adding 1 to the resulting number (read the wikipedia article linked above for more information...)
Unread 14-01-2007, 23:12
Phalanx's Avatar
No, it doesn't matter what the language is, the representation is identical.
Fortran, Cobol, C, PL/1, Pascal, APL, ect... it's all the same internally.
Unread 15-01-2007, 00:24
AKA: Dr. Brooks
no team (WRRF)
The posts in this thread have so many errors that I am not
going to try and correct them all. I would suggest that you
download and read Chapter 6 of
http://srvhsrobotics.org/eugenebrooks/IntroCProg.pdf
There are 10 kinds of people in the world, those who
understand binary, and those who don't...
Have fun,
Eugene
Unread 10-02-2007, 15:18
sdexp's Avatar
sdexp sdexp is offline
Imploding Piston
AKA: Sumit Dutta
FRC #1111 (Powerhawks)
sdexp is on a distinguished road
Send a message via MSN to sdexp
1111 = our team number = 15
100000000 = 256
10000000 = 128
.: Sumit Dutta :.
2004RobotExcitement * 2004RobotQuality = 2005RobotExcitement * 2005RobotQuality = 2006RobotExcitement * 2006RobotQuality = 2007RobotExcitement * 2007RobotQuality
Due to Conservation of Madness
South River High School Robotics
Team 1111
Powerhawks
Unread 14-01-2007, 22:59
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
An UNSIGNED byte can represent a value between 0 and 255.
A SIGNED byte can represent -128 to 127.
You must know what type of byte you are working with. This is the whole purpose of declaring variable types.
Unread 14-01-2007, 23:03
wow, things are becoming clear to me now in declaring variable types. before, I'd never really cared about it (mostly because I was doing stuff where declaring variable types weren't required such as programming a calculator and MatLAB). Thanks
Unread 10-02-2007, 21:28
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Actually, 4 bits provides 16 possible combinations of 0 and 1 so it can represent 0 to 15 as an unsigned integer or -8 to +7 as a signed integer.
(unsigned integer in this case being a mathematical term rather than the C type).
Yes, typically computers represent signed integers as two's complement so negative numbers have the high bit set.
Refrain from the negatives Arefin Bari General Forum 19 10-05-2006 22:43
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
binary in C sciguy125 Programming 9 13-11-2005 22:12
Binary in Rose is Rose MisterX Chit-Chat 8 11-02-2004 18:26
delphi: binary sort archiver 2000 0 24-06-2002 00:30
