V13 Master Code
Here is the new version of the master code for the 04-07 controllers.
Re: V13 Master Code
How do you update the master code in the robot controller?
Re: V13 Master Code
In easyC goto the terminal window then under the options menu select "Update Master Code" then specify a path to the .bin file.
In the IFI loader just hit browse and then select .bin for the file type and specify the path to the .bin file. |
| Need: Master Code | JamesBrown | Programming | 1 | 09-01-2007 21:53 |
| Master Code 11? | SteveO | Programming | 5 | 22-04-2005 19:48 |
| Master Code? | HolyOne207 | Programming | 4 | 12-01-2005 22:32 |
| 2005 RC Master Code | or yaniv | Programming | 8 | 12-01-2005 12:05 |
