Go to Post FIRST games are complex and rely on design and intellectual capability much more than the average sport. - Chris is me [more]
Unread 15-01-2007, 13:37
K.Porter's Avatar
K.Porter K.Porter is offline
Not So Random!
FRC #0172 (FALGOR)
Team Role: Electrical
K.Porter will become famous soon enough
Send a message via AIM to K.Porter Send a message via MSN to K.Porter
Team 172 Prototyping
While our final design is still being worked out in the computers, we've assembled a simple gripper onto our 2004 Tetra bot, showing how truly simple a robot can be and still function in this game. If it hadn't been assembled two years ago, the robot you see in these pictures would be quite capable of competing (minus a few small technical updates in the rules and whatnot) and it would be able to score on all goals.
...Now if only our engineers and students in the back rooms could get that into their heads and design something this simple!
Essentially, it's a single pneumatically actuated solid boom on an A-Frame, with a three pronged pneumatic gripper made of aluminum tube from around the shop, and a little bit of surgical tubing (so that we don't poke any more holes in the tubes than we need to...). All the upper mechanisms are pneumatic and rather lightweight, and it only really has two moving parts for the whole gripper mechanism. Simple and effective.
Unread 15-01-2007, 16:11
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Re: Team 172 Prototyping
can you safely control the height of your arm or does it jerk up and down as you actuate it?
and...How do you control the height?
Unread 15-01-2007, 16:26
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
The arm moves quite smoothly with the rings as a load. We have flow control valves on the pneumatics at both ends, so the arm moves at a rather constant speed up and down. (although, it admittedly is a little more jerky on start/stop then I would like. It's bearable)
As for height, it's currently just by eye. For the Tetra competition, we did mount magnetic sensors on the cylinder, that would act similar to limit switches when the piston reached points within the pneumatic cylinder, but they were never wired for that competition. We could do similar for this years after a little bit of tweaking to figure out the heights of the rack relative to the arm.
Most likely, though, our lift arm will be powered by an electric gearing rather than pneumatics, although in a very similar configuration.
Unread 15-01-2007, 17:03
RichardJames's Avatar
RichardJames RichardJames is offline
AKA: Eric
FRC #0296 (Northern Knights (or Northern Ninjas))
RichardJames will become famous soon enough
This looks great as a concept, I love simple bots! When teams focus on designing things really well instead of arguing concept the results are always fantastic.
Maybe you could include something to rotate the wrist and change orientation of the tube for scoring?
also, it looks like this bot probably falls well below regulation weight... am I wrong? maybe you could devise a way to eliminate any CG issues and raise stability.
To design a good mechanical system, you have to design something so simple it almost doesn't work, then increase the complexity until it does.
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
Nice gripper mechanism! Simple, yet very effective.
But for your arm, watch out for <R12>...you might be pushing it from what the picture shows.
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
Unread 15-01-2007, 18:02
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Nice and simle.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
Unread 15-01-2007, 18:10
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
We do plan on adding a simple wrist mechanism on the final design, with something close to 120 degrees of rotation around a pivot.
As for weight, the base robot still is using the old gearboxes, 4 CIM motors, and a good amount of 8020, so it is up there in weight (~110 lbs), but with the new drive train this year, and some strategic use of materials, a robot could be re engineered around the same basic design and easily save 20 lbs.
And, thanks for the heads up technoL. This robot would be pushing it in regards to <R12>, and we'll definitely look into that before we decide on something final.
Unread 15-01-2007, 21:41
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Reminds us of our Team 987's robot in 05...are you sure the two foot piston is legal this time around? We didn't see your piston on the order form for this year's build.
Unread 15-01-2007, 22:00
K.Porter's Avatar
Not So Random!
FRC #0172 (FALGOR)
I do not think that the piston is legal this year, that's why we're turning towards an electric powered chain/sprocket for the new build.
Unread 16-01-2007, 00:28
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
The 2' piston is legal, it just has to be 2" in diameter (or 1.5" according to the Bimba site for some reason).
296 prototyping RichardJames Robot Showcase 13 16-01-2007 12:38
pic: when prototyping goes wrong Whalley Extra Discussion 13 01-02-2006 21:31
LEGOs for Prototyping? psychoCHIPMUNKK General Forum 14 22-01-2005 11:48
LEGO Wheels for Prototyping dddriveman General Forum 1 26-06-2003 13:02
