Go to Post kids these days, with their fancy aluminum sprockets, don't know how good they have it. - AllenGregoryIV [more]
Unread 17-01-2007, 17:13
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
MPLAB Question
I know there are quite a bit of threads about this, but I couldn't find the problem i have. I get a build error right off the bat on my first open and build. I remember needing the go into build options and adding the C:\mcc18\lib and h directories. The problem with this, is that it still doesn't help. I then looked for the mcc18 directory and cannot find it in the C:\ directory. Could this be the problem? Or any other solutions?
TEAM 1706
2007 Judges Award, St. Louis (For our amazing ability to have bad luck)
2005 Rookie Inspiration Award, St. Louis
Unread 17-01-2007, 17:26
Electrical Engineer
Rookie Year: 1995
Re: MPLAB Question
Uninstall MPLAB and C18 and then reinstall. Install MPLAB first and then C18. Pay attention to the default locations for the installation. Default for C18 should be C:\mcc18
Mike
Mike Betts
As easy as 355/113...
Unread 17-01-2007, 17:27
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: MPLAB Question
If you dont have a c:\mcc18 folder than yes, that is an issue. Have you installed C18 compiler?
Unread 29-01-2007, 20:16
skrew-ball skrew-ball is offline
None #0975
skrew-ball will become famous soon enough
Re: MPLAB Question
I know you simply say to uninstall the compiler and reinstall the compiler, but I have the compiler installed on my school's computer. It took about a month just to get it installed and it would take up the rest of the wait until competition to get that done. My only question is whether I can download the file and just simply put it in the dir. This wouldn't normally be possible, but it is already linked to in the windows registry. So I should be able to cut and paste it. Now where can I get that . . .
Unread 30-01-2007, 09:35
Re: MPLAB Question
If it was installed for you by the school, then perhaps they put mcc18 somewhere other than the default location which would be alright as long as you tell MPLAB where it is.
Try searching the computer for mcc18.
MPLAB IDE rholokleolke Programming 13 08-12-2006 18:32
MPLAB ThienAn Programming 10 08-12-2006 18:06
Oh my! MPLAB is free! RIgnazio Programming 8 04-11-2005 23:43
Mplab WesleyBalmer Programming 6 14-01-2005 15:23
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
