Go to Post Imagine your crate going over Niagara Falls => pack it accordingly (esp if you are attending the Toronto Regional :^) - KenWittlief [more]
Unread 17-01-2007, 23:14
Team 849 Team 849 is offline
FRC #0849
Team 849 is an unknown quantity at this point
Servo & Tracking Problems
We're having problems with the servos and our camera can't track. We tried using the demo program and it still doesn't work. What's wrong? The camera can move with the joystick but the autonomous doesn't work either.
Unread 17-01-2007, 23:19
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
Re: Servo & Tracking Problems
Are you using EasyC or Kevin Watson's camera code?
What pwm output ports do you have the servos connected to? The 2007 easyC demo code expects pan and tilt to be on pwm 10 and 11 by default, respectively. You can change this with the macros and constants dialog by hitting F6 in easyC. Kevin's code by default has pan and tilt on pwm 01 and pwm 02. That can be changed by editing the values defined in tracking.h.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 18-01-2007, 16:20
FRC #0849
We are using Easy C.
The macros and constants are empty when we press F6. We are using pwm 10 and 11.
How do we activate the autonomous mode?
Also, is there a seperate chip that is needed to pan and tilt the camera?
Unread 25-01-2007, 10:12
sniggel sniggel is offline
FRC #2051
sniggel is an unknown quantity at this point
We figured out that you can enter autonomous mode by jumping pins 5 and 8 on the competition port. We got the info from the 2005 operator interface guide from FIRST, page 12.
Be careful, you don't want to fry the brain, at least a dozen teams fry them each year.
Unread 28-01-2007, 01:28
htwiz2002's Avatar
htwiz2002 htwiz2002 is offline
Htwizard
AKA: Anthony Takata Bawahawba
#1290
htwiz2002 will become famous soon enough
Unhappy Re: Servo & Tracking Problems
We are attempting to use the onboard pwms on the camera. Our last-year's programmer had got this to work, but since he is gone (and also the laptop) I can't seem to figure it out. I am using Kevin's camera code (streamlined?)
Any ideas?
Edit:
I just read Rule <R28> revision #2 which stated that i could not use the 2006 camera! Oops . Well, I guess i need to get longer pwm cables! . Oh well, just go with the flow...
TsAuKpAeTrA (Anthony)
Problems with tracking Shinsa Programming 2 07-02-2010 14:35
Quetion about servo tracking function in easyC pro itsme Programming 5 31-01-2007 11:30
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
Tracking beacon without servo Paul Marshall Technical Discussion 17 10-02-2004 20:58
servo problems lpramo55 Programming 5 20-01-2004 22:23
