Go to Post It was the stupidest rule, but a rule is a rule, and everyone has to follow them. - RyanN [more]
Unread 18-01-2007, 17:19
foote stepped in
AKA: E. Foote
FRC #0868
Broken Camera -- Help
A member on our team hooked into the camera the power pwm backwards, and now it won't turn on.
any suggestions, or ideas? Any help is appreciated.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 18-01-2007, 17:32
Bharat Nain's Avatar
Re: Broken Camera -- Help
It's most probably fried. Check IFI forums or call IFI for further assistance.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 19-01-2007, 13:49
foote stepped in
AKA: E. Foote
FRC #0868
i sent them an email... hopefully I'll get a response
Unread 19-01-2007, 14:47
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
To my knowledge, this should not damage the camera. The PWM cables are configured in a way to prevent damage by simply reversing the connection. This is because the positive voltage (red wire, in this case around 7.2v) is always in the center, and instead you are only swapping the ground (black) and signal (white) wire. Was the serial connection connected to the RC when this happened?
Unread 19-01-2007, 23:38
foote stepped in
AKA: E. Foote
FRC #0868
Actually, we figured it out. They were using a low backup battery. ::sigh of relief:: Consider this thread closed, and good luck to everyone!
Unread 20-01-2007, 02:50
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Gah, thank you for the confermation. I pluged a few of my PWM backwards all the time and I was afraid as, someone said, that it is fried.
Well, back to trying to understand how to conncet the camera... :|
Unread 20-01-2007, 04:20
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Low Backup Battery is a problem that my team had last year as well. What we ended up doing was using a VEX 7.2 v NiCad battery instead since they are the same batteries that are found in RC cars and other such items. They are legal under the FRC 2007 rules as well.
The other options is to use the wire diagram on the IFI site to make a battery charger that charges from the 12V battery, in which case it does not matter what kind of battery pack is used for the 7.2V's.
My Blog!
Unread 28-01-2007, 09:45
AKA: Nir Levanon
I accidenlty tried to use the BIN files to upload to the code(didn't work of course). I switched it back to the HEX and SOMETHING actually happened. The COM said that there was no camera data, but when I looked at the camera, the red light disappeared. I did it again, then the green one disappeared. Does that mean that the backup battery is running up of power.
Broken Camera! agentderek Electrical 6 15-01-2007 22:12
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Broken RC Please help ~<-Bendr->~ Control System 7 15-03-2005 00:19
Broken RC Please help ~<-Bendr->~ Technical Discussion 7 15-03-2005 00:19
Broken promises or BROKEN ROBOTS! archiver 1999 9 23-06-2002 22:18
