Go to Post A 823543:1 reduction should be fine if you ever need to pick up a truck...or a house. - Tim Sharp [more]
Unread 19-01-2007, 21:50
Turdmoe Turdmoe is offline
Turdmoe is an unknown quantity at this point
linking error
I got a "linking error" when I compiled my code:
".code_sqrt.o' can not fit in the section. Section ' code_sqrt.o' length=0x00000442"
what does this mean?
Unread 19-01-2007, 22:17
Re: linking error
It looks like your floating point calculations have completely filled your processors memory.
Unread 27-01-2007, 19:01
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Re: linking error
If you are only using the sqrt function, you might like to see the implementation of InvSqrt():
http://www.beyond3d.com/articles/fastinvsqrt/
here is an implementation that I compiled on my first controller (the scary constant is a standard IEEE754 floating point number, so it will work on every microprocessor the same way).
I would definitely extensively test this method before putting it to use (i.e. don't hook up motors until you are sure it gives the expected answers), but I believe that it is just a first-order Newton's method approximation, with the constant being a first guess I believe.
I'm pretty sure it will take up less space than the included math library.
float invSqrt(float magnitudeSquared) {
    float xhalf;
    float temp;
    long i;
    // magic follows:
    temp = magnitudeSquared;
    xhalf = 0.5f*temp;
    i = *(long*)&temp;
    i = 0x5f3759df - (i>>1);
    temp = *(float*)&i;
    temp = temp*(1.5f - xhalf*temp*temp);
    // temp now contains the 1/sqrt(magnitudeSquared)
    return temp;
Definitely works on the computer:
5629.000:     InvSqrt 0.013318; 1/sqrt 0.013329
281.0000:     InvSqrt 0.059639; 1/sqrt 0.059655
28.00000:     InvSqrt 0.188722; 1/sqrt 0.188982
6.000000:     InvSqrt 0.407681; 1/sqrt 0.408248
4.000000:     InvSqrt 0.499154; 1/sqrt 0.500000
2.017857:     InvSqrt 0.703756; 1/sqrt 0.703971
0.250000:     InvSqrt 1.996614; 1/sqrt 2.000000
0.166667:     InvSqrt 2.445322; 1/sqrt 2.449490
0.000000:     InvSqrt 19817753709685768192; 1/sqrt inf
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Error Linking for '05 RC Jon236 Programming 2 12-02-2006 14:30
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
A linking problem T Shap Programming 6 15-01-2006 00:23
weird sites linking to robotics teams robot180 Website Design/Showcase 7 16-05-2005 17:18
Dynamic Linking with PHP plutonium83 Website Design/Showcase 6 12-01-2005 19:41
