Here are the results of our test of two calibrated default joysticks. We used a ruler to see the changes in mm every 20 y values (using dashboard to see the values). We have concluded that they are linear.
Another Link To The Graph Last edited by NinJA999 : 19-01-2007 at 21:59. Reason: Link to site |
Re: Joystick Linearity
They better be! They use linear potentiometers, after all.
That said, the linearity of the joystick can be misleading. If you do open-loop drive control (i.e. pwm01 = p1_y), you will find that the speed of the motor on pwm01 will NOT increase linearly over the entire range of the joystick. |
Right. We have implemented code that makes the pwms linear, and it runs so much more smoothly now.
We implemented a look up table to purposely make them nonlinear. We like more sensitivity around the center to make it easier to drive slow and precise. We lose sensitivity at full speed, but when you want to go fast sensitivity is not as important to us.
Interesting. To do that we implemented a reduced speed switch on the trigger.
| 1 joystick or 2? | ChrisMcK2186 | Control System | 18 | 19-01-2007 23:42 |
| joystick ? | _GP_ | General Forum | 1 | 26-02-2004 23:10 |
| Joystick | rmmlg | Inventor | 0 | 15-02-2004 16:34 |
| No Joystick | archiver | 2001 | 2 | 24-06-2002 01:14 |
| Joystick | Absolute Value | Technical Discussion | 21 | 22-02-2002 10:56 |
