Go to Post However, I am a firm believer in the theory that if you are pushing with a mecanum wheeled robot you are doing it wrong. - Andrew Schreiber [more]
Unread 20-01-2007, 10:32
Golfer241's Avatar
Golfer241 Golfer241 is offline
King of Nerds
FRC #0241 (Astros)
Golfer241 is an unknown quantity at this point
Send a message via AIM to Golfer241
4 inches vs. 1 foot
Team 241's advisor wants us to settle for a 4 inch ramp instead of the teh foot. Would a robot with only a 4 inch lift still be an attractive choice for an ally in the finals?
"Music is like candy, you throw away the rappers."
-me
"Tomorrow is the judgment day, tomorrow we'll discover what our God in heaven has in store!"
-Les Miserables
"There's only us, there's only this, forget regret or life is yours to miss. No other road, no other way, no day but today."
-Rent
Unread 20-01-2007, 10:35
Eric W. Jones's Avatar
Eric W. Jones Eric W. Jones is offline
Rack & Roll, baby!
FRC #1646 (Precision Guessworks)
Eric W. Jones will become famous soon enoughEric W. Jones will become famous soon enough
Re: 4 inches vs. 1 foot
that depends. What else can your robot do? Will it have a good game piece manipulator? Will it play defence? There are other factors to consider for alliance partners.
2006 Boilermaker Regional
2006 Buckeye Regional - Third place overall
2006 Atlanta Finals
2006 IRI
2007 Boilermaker Regional
2007 St. Louis Regional
2007 Finals (hopefully )
2007 IRI
Why, yes. I do know what I'm doing!
Unread 20-01-2007, 10:38
Golfer241's Avatar
King of Nerds
FRC #0241 (Astros)
We have an arm design that will be moderatly efficient. and we plan to be able to play defense, but we can't say anything for sure.
-me
-Les Miserables
-Rent
Unread 20-01-2007, 10:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
15 points is better than zero points....if it looks like you might not be successful designing and building a 12" system, but you can easily do a 4" system, then do what you can. 15 points is better than zero points (yes, I'm repeating myself)
Unread 20-01-2007, 11:08
Golfer241's Avatar
King of Nerds
FRC #0241 (Astros)
I just dont feel like we should settle for 4 inches. With our design the ramp would be large enough for one robot and if we went for the foot the incline would only be 14.5 degrees. I think the team can do it, but our advisor disagrees.
-me
-Les Miserables
-Rent
Unread 20-01-2007, 11:18
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
You have to remember also that a lot of teams will be able to climb on a four inch ramp but not a twelve. We also looking at a four inch platform but with adjustments based on our alliance partners that will slide up to 12. This is if we have the height to store it before unfolding. We have not attached it yet. ALso, our arm works very good with the extension for the top row easy. And we can climb a 12 inch ram if needed.
Unread 20-01-2007, 11:22
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
I think the real question is why you are building a robot...
If the students want to build a 12 ramp then build it. "The robot is a vehicle to build better people not the other way around." Sometimes taking the risk and failing is more productive then not trying to at all.
And one more thing, mentors are here to guide and explain not to decide and do.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 20-01-2007, 11:36
Crtcalmss Crtcalmss is offline
Team Mentor
FRC #0350 (Timberlane Owls Robotics Club (TechnOtus))
Crtcalmss will become famous soon enough
Our team struggled with the decision about ramp size as well. We "fondly" remember flipping backward off last years ramps. We remember so many others doing the same. A 12" ramp, unless mated with a sufficiently long ramp so that a robot 1) does not have the tendency to flip backward 2) does not become high-centered on the transition from ramp up to flat top.
In the end, we settled on a 4" high platform with an extendable ramp that has about a 20 degree slope. Most 'bots, except for those with really low clearance, should be able to climb us. We will be extending twin side-by-side ramps so we can provide a platform for two partners.
There are other additions to our design, but they're not important to this thread. Good luck with your design.
Unread 20-01-2007, 12:27
stoltcclxxxviii's Avatar
stoltcclxxxviii stoltcclxxxviii is offline
FRC #0288 (Robodawgs)
stoltcclxxxviii is an unknown quantity at this point
Our team is possibly going for the 12 in but yes I agree that the 12 in ramps will be harder for some robots to climb and a four inch would be much easier for a bot to move up without tipping.
Unread 20-01-2007, 13:19
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
I don't want to get into an argument about it in this thread, but depending on their team's structure, that may or may not be the truth. If you want to further discuss it, please go ahead and PM or IM me.
Unread 20-01-2007, 13:40
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
we are a rookie team but we are going to win the rookie all star award simply because we are wayzata. any ways we are going to go for 12 inches and we also have an ingenious plan that will let even weak robots climb onto us.
Unread 20-01-2007, 18:41
evanisthat!'s Avatar
evanisthat! evanisthat! is offline
Captin' Kassof
AKA: Evan Kassof
evanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really niceevanisthat! is just really nice
Send a message via AIM to evanisthat!
In the past, we have found that "Jack-of-all trades" robots are never as good as consistent robots with fewer features. If you can reliably provide an extra 15pts to every match, then you would be an attractive alliance partner for that reason alone. Consistency is key.
EDIT: I see Arefin beat me to the same message, he knows just as well as I do. Consistency is Key. We were ranked 79th or so on Curie in 05 and got picked and won the division because we were ranked 6th in scoring consistency. (That was according to team 66 i believe who scouted and provided that info)
108!!!
2007 Las Vegas Xerox Creativity Award winners!
2007 Las Vegas Quarter Finalists, only alliance to challenge the champs!
2007 UCF Finalists... thanks to 1902, 179, and 386 for the crazy jump in!
2005 UCF regional quarter finalist...
2005 Midwest regional quarter finalist...
2005 UCF Website Winner
2005 Midwest "Delphi Driving Tomorrow's Technology" Award.
2005 Championship Curie Division Champions. (thanks to team 175 and team 33).
Unread 20-01-2007, 20:35
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
From a strategy standpoint if one of your teammates can make it up the 12 ramp for 30 points and the other teammate can continue capping, that will be more advantageous than having 2 teammates back at 12 inches for 30 points.
I do not know your situation with your mentors but sometimes they will underestimate what students can do so thats something you have to work around/with. What you go for should really be democratically decided as a team with everyone(mentors students parents etc.) getting a vote for what they want to do.
KK4KQO
http://voltair.us
Unread 20-01-2007, 21:01
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Does your advisor have physical evidence to back his/her opinion up?
Or does he/she not feel you have the capability to do the 12" ramp?
Something doesn't seem right from my point of view. I don't mind your advisor disagreeing, but he/she should encourage your ideas and help you make them a reality. Our team decided to go with a mecanum drive this year, and many engineers said to us that it will be a great challenge. They never said "Don't do it".
This is so true.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 20-01-2007, 22:49
DonRotolo's Avatar
Back to humble
FRC #0832
I agree with Arefin & Evan, doing one or two things really well and consistently is far better than doing a lot of things inconsistently.
Of course, the key is to anticipate what will "win" the "game". For example, in last year's game, a team that could score well enough to win autonomous (almost every time) AND climb the ramp consistently did not really have to do much of anything else to win the game. Sure, you needed someone who could score a little, and sometimes you lost from a technical issue, a weak alliance, or a strong alliance opposing - but 80% of the time, your alliance won.
Don
Top spider foot Robo_Coyote General Forum 2 19-01-2007 22:07
pic: 2004 Robot+ 2 Ringers= 12 inches 358_4_Life Extra Discussion 5 16-01-2007 08:11
spider foot offset Drew General Forum 8 14-01-2007 02:24
pic: 612 rollin on 6 inches Priyadarshy Extra Discussion 6 12-10-2006 15:46
Anyone need a 100 foot lathe? dlavery Chit-Chat 9 06-12-2005 00:35
