Go to Post FIRST has stated time and again that the program is not about teaching (they always refer to the I and R in FIRST) - Dave Flowerday [more]
Unread 20-01-2007, 13:03
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
Mystery Sprockets
Before I start, let me preface this by saying that yes, I know there is a previous post on the subject. However, the answers to this post did not lead to a productive answer to the question.
Here's my question: where can our team find more sprockets for the KoP wheels (the normal wheels contained in the kit)? We've looked on and off for the last week. We finally found something we thought would work, but the screw-holes didn't line up.
We know this part number is the one that didn't work out: 35377159. I don't think our team has the capability to machine the steel, so we need something with pre-drilled holes.
One last request: if you know where to find these, just say so; please save the "search before you post" rhetoric for later.
Thanks,
Paul Dennis
Team 1719
Unread 20-01-2007, 13:14
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Mystery Sprockets
Do you really need the steel sprockes, or could you use the aluminum ones from IFI instead? they include spacers, so you can mount them out from the wheel a ways. You may need to tap threads into the holes in the wheels. I haven't tried to put the aluminum sprockets on the new AM plastic wheels, but the bolt pattern seems to be the same (6 each 10-32 on a 1.875" circle), so they should work.
Unread 20-01-2007, 17:27
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
Our mentors have told us that normal operation of the wheels places significant wear and tear on the wheels such that you really should use the steel sprockets. However, if you know this isn't the case, could you elaborate further?
Thanks,
Paul Dennis
Unread 20-01-2007, 18:06
Billfred's Avatar
Billfred Billfred is offline
Thanks,
Paul Dennis
If the robot were running for months straight, then yes, steel would probably be in order.
However, you're running your robot for two minutes at a time, perhaps 50 times tops over the course of a competition season (unless you go to a metric ton of off-seasons). In that sort of situation, I have empirical evidence that suggests that aluminum sprockets, such as those sold by IFI, AndyMark, and perhaps others, wear acceptably. If you're really worried about it, bring a couple of spares (though you should do that as it is)...but you should be fine in most situations with the aluminum sprockets properly installed.
Unread 20-01-2007, 18:25
Gdeaver Gdeaver is offline
FRC #1640
WE used the IFI AL 28 tooth sprockets last year with Custom made spacers on the Skyway wheels. IFI is selling 24 tooth AL sprockets. If used with the Andy Mark KOP wheels, I would recommend some type of reinforcing Spacer.
Unread 20-01-2007, 23:24
MrForbes's Avatar
AKA: Jim
The wheels use rather large sprockets, with many teeth, and usually the chain wraps more than half way around the sprocket, so the load on each tooth is relatively small. The aluminum sprockets are strong enough for use on wheels, and the smallest size you can commonly get is 24 teeth, I believe.
However, the transmission sprockets are a different story. Some use as few as 9 teeth, so the load per tooth is significantly higher.
The general way of doing things is to use steel sprockets at the drive end of the chain, and aluminum sprockets at the wheel end of the chain. It works.
Unread 21-01-2007, 00:50
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Originally Posted by Ben Piecuch View Post
After a couple quick emails, I was able to find several teams in the area that were willing to help me with our broaching needs. Turn-around time was 1 day! Try to find that with any other supplier!
So, even though YOU do not have the resources, there are over 1,000 other teams out there that just may. Don't be afraid to ask another team for help. The broaching took an hour of their time, and they were more than willing to actually do the work for me. (I had to fight them off...)
Ben, that is exactly on-point. One of the things that every new team learns is that there is always more than one way to skin a cat. Need to add more sprockets to the robot? Get additional parts similar to those in the Kit Of Parts. Can't find exact duplicates? Get one that is close enough, and work with it to allow it to be used. The sprocket doesn't have the right bolt-hole pattern? Borrow a hand drill and drill out a new one. Don't have the right skills to drill the new holes yourself? Talk to your mentors and see if they can help. They don't have the right skills? Talk to nearby teams and see if they can send someone over. They can't make it? Take it over to them and see if they can do it on site..... etc etc etc
There are lots of ways to get things done. It takes some perseverance, creativity, and innovation, but one of the great things about FIRST is that there is a tremendous community out there to help you make it happen if you can't do it all yourself. My fundamental point is that before you have to resort to buying your a way out of a problem, make sure that you really tap all the resources that you have at your disposal. Some of them may not be obvious at first, but they are there and can add to your experience.
-dave
Unread 21-01-2007, 10:03
MrForbes's Avatar
AKA: Jim
One untapped resource could be a "KOP sprockets wanted" post on CD....my guess is many teams are not using them, and there are literally several hundred of those sprockets sitting on shelves and in boxes going unused, right now, as we speak. I personally know of a pair of sprockets, but I don't have authority to give them away.
You migth check the rules first though, as the parts might not be available for sale anywhere, so using "free" ones might not be allowed.
Unread 23-01-2007, 17:32
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
As I read <R43> it would prohibit the use of extra "kit" 24 tooth sprockets obtained from other teams, since that part is apparently not a COTS component. A team that is considering using more than two of the "kit" 24 tooth sprockets (i.e., using more than the quantity included in the 2007 kit) should post a question on the official Q&A site to see if this will be allowed.
Richard Wallace
since 2003
Unread 23-01-2007, 22:30
MrForbes's Avatar
AKA: Jim
Wow, it's nice to see I could come up with a tough question, without even trying
Unread 25-01-2007, 21:03
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Good catch, Richard.
http://forums.usfirst.org/showthread.php?t=1834
Originally Posted by Official Q&A
The sprockets provided in the 2007 Kit of Parts were custom manufactured for FIRST and are not COTS parts. As such, only the two 24-tooth sprockets received in the Kit may be used on your Robot. Teams are welcome to fabricate equivalent parts from COTS items.
Looks like any teams who have borrowed kit sprockets from others are going to have to find an alternate solution.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 25-01-2007, 21:35
When did you see this, Karthik?
I just tried the link above and got "you do not have permission to access this page".
Richard Wallace
since 2003
Unread 25-01-2007, 21:37
Weird, I got the same message. I saw it just after 9:00 pm.
Unread 25-01-2007, 21:52
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Also, it seems that what Karthik pasted is directly in contradiction with another Q&A, which asked where to obtain KOP sprockets.
Altenately, you may want to check with some nearby teams and see if they will be using these parts. Many teams choose not to use the Kit Of Parts-supplied drive system, and may have them as spares (note that if you do obtain them from another team, they still must be fully accounted for the in Robot Bill Of Materials).
I don't think I'm reading between the lines here... that definitely would mean to me that you could use additional KOP sprockets, so long as you accounted for them.
http://forums.usfirst.org/showthread.php?t=1508
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 21-01-2007, 14:30
aaeamdar's Avatar
Post-A-Holic
AKA: Paul Dennis
-dave
The first point I would make about this is that you should be able to find more of the types of things that are in the Kit of Parts. There should be a FIRST-related site where you can go and order more of any part that comes with the kit. I know, for example, that IFI Robotics has part of this list (but only with the things they make, obviously). Why are you not able to just go online and order another part? If the answer is that FIRST wants us to practice our drilling skills, then why do the sprockets in the KoP come pre-drilled?
Furthermore, I understand that there's more than one way to get things done. We've already ordered two omni wheels from Andy Mark to see if we can come up with some other solution than 4WD. However, we also wanted to look into the possibility of getting more sprockets. I'm also not sure why you think we should be looking for the most complex solution to a problem (buying pre-drilled or at least easily-drillable parts seems much simpler than drilling new holes in a steel part, which our mentors tell us is much more difficult to machine). We also did ask local teams if they had extras of these parts, and we have not yet gotten any replies.
When we're trying to solve a problem as simple as our drive train, we're going to be looking for a simple solution; getting two more KoP sprockets should be doable. We are examining the alternatives, and one of them should be to get these sprockets. You seem to be critiquing me for not doing exactly what I'm trying to do with my post.
Am I reading this wrong?
Paul Dennis
tachometer mystery? Issues Motors 31 27-11-2005 20:44
pic: 930 Mystery Teaser Gamer930 Robot Showcase 3 14-02-2005 12:03
mystery theater help hollieteam388 Chit-Chat 0 21-01-2004 17:45
Mystery Science Theater 3000 Ryan Dognaux Chit-Chat 3 18-08-2002 16:49
mystery icons Joe Johnson CD Forum Support 2 07-06-2001 22:09
