Go to Post How about "Lebron"? Wait, no, you'll be dooming yourselves to failure the last 30 seconds of every match. - Travis Hoffman [more]
Unread 20-01-2007, 17:06
Nicodemus Nicodemus is offline
Head Electrician of 1599
FRC #1599 (Full Metal Racket)
Team Role: Electrical
Nicodemus is an unknown quantity at this point
Question about Gear-tooth?
Ok I have searched through this forum and through the manuals but I still have a question about how to actually wire the gear-tooth sensor if someone could please send me a link for that or explain it to me I would be greatly appreciated. I have a feeling I know how it goes but last year I fried two and I'm just not sure.
Unread 20-01-2007, 17:59
Commander07 Commander07 is offline
FRC #1730
Commander07 is an unknown quantity at this point
What exactly is the Gear-tooth sensor used for?
Unread 20-01-2007, 18:08
Re: ?
It's for detecting the passage of gear teeth past the sensor. Its output turns on and off in step with the metal teeth going by. When it is connected to a digital input on the Robot Controller, the software can set things up to count the pulses and thus tell how far the gear has turned in a given amount of time. It's useful for speed and/or position feedback on a motor.
Last year the TechnoKats used gear tooth sensors on the output of each gearbox for the drive wheels. In autonomous mode, that let the robot know how far it was traveling and how much it was turning, so it could control its motors to get to where it needed to be. I know a few teams used them to monitor and adjust the shooter wheel speed.
Unread 20-01-2007, 21:11
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Re: Question about Gear-tooth?
Everythng you need to know is in this thread......
http://www.chiefdelphi.com/forums/sh...t=51840&page=2
First off, download and read Kevin Watsons encoder code and encoder FAQ
http://www.kevin.org/frc/encoder/
http://www.kevin.org/frc/frc_encoder.zip
To make his code work with the gear tooth sensors you need to remove the "Phase B" logic from it.
Second you wire them to digital I/O 1 and digital I/O 2 with a pwm cable. You also need to power them on a 12volt power supply as well.
See the 2007 Sensor Manual for more information.
To wire the sensor...
Take one end of a pwm cable, and solder it to J2, the black wire to GB (ground-black) the red wire to 5R (+5 volts-red) the white wire to SW (signal white). Connect the other end of this pwm to digital I/O 1.
Take a 2nd pwm cable and solder it to J1, the black wire to GB, the white wired to (12W), the red wire is unused. Connect the other end to a 20amp circut on one of your atc breaker panels.
Mount the sensor from .5 to 2.75 mm away from the gear to be measured.
Repeat this for the second one except connect it to digital I/O 2.
As for the code...
Use encoder 1 and encoder 2, disable the others. Then remove the "Phase B" logic in the interrupt handler for encoder 1 and encoder 2.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 21-01-2007, 02:19
Thank you... though the code information and the such I don't need I'm just an electrical person anything doing with code goes right over my head I just know that our programmer wants a gear-tooth sensor working and I'm just trying not to fry it this year. Thank you again I really appreciate it.
Gear Tooth Sensor Zoom Programming 46 22-01-2008 08:05
Quick question regarding the gear tooth sensor... Brad Voracek Electrical 3 12-01-2007 01:07
Question About Gear Boxes CE Mexican Motors 5 19-12-2006 15:14
Gear Tooth Sensor nukem Programming 9 04-02-2006 20:21
Gear Tooth Sensor Question (InsrtNameHere) Electrical 2 20-01-2006 02:19
