Rookie team Question error 7
I am using labview with the cmucam2 app, when I press run I error 7 occurred at open file+.vi
pen file. I need help to move foward. |
Re: Team 868
We are getting this same problem and do not know where to turn next. Our team did have the camera working once but now we only see the following when LabView application is started. Installed NI Visa but this did not appear to help. Using USB to Serial connection on camera and this is picked up in Visa Interactive Control. Only seeing green light on camera when is is powered on. Did see red once before but not now. Also need assistance!!!!!!!
-1073807246 Property Node (arg 1) in VISA Configure Serial Port (Instr).vi->CMUcam2.vi->CMUcam2 GUI.vi |
Re: Rookie team Question error 7
We are still having problems and get the following error when camera is powered on and application is started in Labview. Followed all instructions in PDF FRC2006 Labview-based CMUcam2 Demo and see the following error in Labview. Visa is installed and com port is configured correctly. Can any one help.
-1073807339 VISA Read in query for result from serial port.vi->CMUcam2.vi->CMUcam2 GUI.vi |
http://www.chiefdelphi.com/forums/sh...83&postcount=9 If you cannot get anything to come out of your camera, and you are dead sure your camera is being powered at the correct voltage, then you may have a bum camera. I'd like for you to debug this a bit more before saying you have a bum camera, however, since bum cameras aren't a common occurrence. -Danny |
We also have this problem. After error 7, at the bottom, it says NI-488 board not found. What is this? Will try the other steps tomorrow & hope it helps.
-Danny |
#7
We went through some process using MAX and setup the COM port, then it started working for us. I don't remember what the exact steps were, though. If no one helps you out by tomorrow then I can give you instructions from the team's laptop.
#8
Please remove the current CMUCam2 LabVIEW application from your computer, and download the package provided in this post: http://www.chiefdelphi.com/forums/sh...9&postcount=10 This should work without problems. -Danny |
#9
so that's what the problem was! thanks for clarifying that, we may get labview working soon! ![]() |
| Rookie question, appoligies in advance | s_forbes | Technical Discussion | 2 | 13-01-2006 01:30 |
| Rookie Question | joeblob | General Forum | 2 | 18-12-2004 11:22 |
| rookie question | haverfordfords | Robotics Education and Curriculum | 2 | 06-12-2004 18:27 |
| Rookie Question. double solenoids... | archiver | 2001 | 2 | 24-06-2002 00:57 |
| Rookie question | archiver | 2001 | 8 | 23-06-2002 23:21 |
