CPU Load in FRC RC
It has been years - no, decades - since my last programming class. (We used punchcards, if that's a clue...).
My question has to do with the relative load on the CPU for the various programmatical operations that can be performed. I was always under the impression that an IF statement took a lot more CPU time than a series of 3 or 4 simple additions - but a thread near here made me re-think that belief. So, can anyone explain to me the load on the CPU of the various operations, particularly Math (integer and quasi-floating [bit shifts?], if there's any difference), Logical comparisons (<=), Conditionals, and I/O statements (and what else did I miss?). Also, my assumption is that if I do a certain calculation, it takes as long to do it in a 'subroutine' (or whetever we call them today - a called function?) as it would in the main programming loop. (Ignore proper programming practice, I'm only worried about CPU load) Not looking for exact numbers, a relative comparison would be fine. Even better would be a reference where I could just read on it myself... Thanks, Don |
Re: CPU Load in FRC RC
Sure, certain operations take a certain amount of tics to complete, however none of the operations you have mentioned would require more than it could handle, not even close.
I have no references, but each operation takes a certain amount of assembly, which requires a certain amount of CPU tics to complete. Is there any specific reason as to why you are asking for this information? I personally do not see a reason to worry about how many tics a certain operation takes to succeed. One thing you mentioned was if it would take longer in a subroutine (functions these days), or in the main loop, both would take the same time. Calling a function however does take some more tics than having all your code in the main loop, however it is so VERY little, it is negligible, and for the sake of being able to read your own code it is better you keep it in there. |
Alright, at the very least, I can state that IF statements won't cost much programming time. The PIC isn't a pipelined processor, so you don't lose time from a branch, so it's not particularly costly. Secondly, doing a calculation in a function/subroutine incurs a fairly significant processing cost versus not doing so. This is mostly because when you call a function, the program has to build a stack saving the current processor state and possibly passing arguments so the instructions in the function can operate in a clean environment. It's not a huge hit, something on the order of 10-20 instructions depending on things, but it does take time.
Edit: X-Istence, computation time can be very very important if you're coding an interrupt service routine or other bits of code where you want things to happen very very quickly. Calling 20 different functions in an interrupt just to keep your code clean isn't a good idea at all. If you want to use functions to keep code clean, I think you can make them inline functions. An inline function basically tells the compiler to take the function and paste it into where your function is called. I'm not positive the C18 compiler supports them out of the box, but I'll look into it. Last edited by Kevin Sevcik : 21-01-2007 at 22:45. |
You can look at the listing file to see exactly how many assembly instructions different C operations take.
If you're interested in the relative cost in program space (which translates almost directly to execution time) for various operations, I suggest you try compiling a program which uses those operations and then inspect the listing file to see how the compiler translates them into PIC assembly language. |
Don,
As Alan mentioned, branching instructions by themselves only take two instruction clock cycles (an instruction clock is 4 clock cycles, so the 40mhz PIC processor in reality only has a 10mhz instruction clock. I will be strictly talking about instruction clock cycles in this note). It's the instructions that have to be done within the IF statement that take most of the time, not the actual branching itself. In general, addition & subtraction operations all occur in-line, that is, the actual assembly code is generated separately for each add/sub operation in the routine the operation is found and is quick. For more complex operations (multiplication, division, trig, all floating point operations), the operands are passed to a math subroutine (function) that will perform the actual operation and the result returned to the calling routine. The source code for the math routines can be found in the mcc18 directory if you selected the appropriate option during the original install of the software. Some of these routines actually have min/max/mean clock cycles to execute. Based on a couple of observations, these times do not include the time to copy your arguments to the math variables (minimum 2 clock cycles per byte), or the result back into another variable. It also doesn't include the necessary CALL/RETURN (4 clock cycles). Here are some samples - the math operation only, not the call/return or the passing of the arguments: unsigned char * unsigned char = 6 clock cycles signed short * signed short = 35 clock cycles signed short / signed short = 85 clock cycles average (min 28, max 149) signed long / signed short = 376 clock cycles average (min 84, max 421) any floating point multiply/divide = 1835 clock cycles average any floating point addition/subtraction = 80 clock cycles average It should be noted that the floating point information came from the C18 compiler version 2.2 and may not be the same in version 2.4 (I believe they changed their floating point storage format between these two versions). Trig routines generally will have multiple floating point operations. I assume around 6 multiply/divide for lack of a better number (from a quick scan of the source – I may be way off base). Based on that assumption, a SINE call could consume upwards of 11,000 clock cycles (0.11% cpu). Doing one of these operations in the main loop of your code (approximately 38 times per second) would result in over 400,000 clock cycles per second (>4% cpu) - very costly. I'm not sure if this answered your question or not, but hopefully it helped. Mike |
#7
Thought I'd add some pictures from the PIC16 architecture guide. It defines the two stage pipeline used within the processor with each instruction having 4 clock cyles they name Q1..Q4. You can see in the diagram that the fetched instruction after a branch/call has to be flushed since it is from the wrong pc.
#8
OK, thanks for the details. Different from what I was thinking, and so very helpful.
The reason for the question is to help my programmers generate more efficient code. As everyone knows, there's more than one way to skin a cat in software, and so some careful choices can bring us faster execution. This isn't a really significant concern - not yet, at least - because we're nowheres near the liit of code space or CPU cycles in the loop. But, with some of the things being planned, we may come close to one, the other, or both - and I want to be prepared when we do. Part of this whole exercise is to let kids understand what 'efficient code' means. Again, coming out of the punch card era, where a 1 MHz processor and 100 MB of online disk were very large mainframe characteristics, today's bloated software, while nifty, is misleading. I showed a kid a copy of TinyEd, a work processor for DOS that's something like 6k of .EXE. He didn't believe it, how could a word processor be only 6k big? Compare that to MS Word. Thanks again, I have enough information and references to move forward on my own. Don |
| CPU loop speed | Windward | Programming | 6 | 07-02-2007 15:22 |
| **FIRST EMAIL**/Championship Updates - Load In and Load Out and Finale Ticket Inform | AmyPrib | FIRST E-Mail Blast Archive | 3 | 21-04-2006 11:08 |
| corrupt CPU? | Windward | Programming | 3 | 14-01-2006 15:33 |
| best cpu | _GP_ | Technical Discussion | 28 | 24-04-2004 21:15 |
| cpu | ivanslost | Programming | 1 | 15-02-2003 23:23 |
