Go to Post A 823543:1 reduction should be fine if you ever need to pick up a truck...or a house. - Tim Sharp [more]
Unread 23-01-2007, 17:42
bruss6's Avatar
bruss6 bruss6 is offline
FRC #0843 (Wildcats)
bruss6 is an unknown quantity at this point
A simple accurate timer
What is the easiest and most accurate delay function or a timer in the user routines_fast.
P.S. One more question... Are there any rules against the use of last year's(2006 kevin's) program???
Thanks
Ben Russell
Unread 23-01-2007, 18:08
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: A simple accurate timer
If you need an accurate timer, you need to use one of TIMER0-4. IFI has examples on their website under White Papers. They're easier than you might think. There is otherwise no way to accuratly time things in the Process_Data_From_Local_IO() function as it simply runs as fast as it runs. If you're talking about timing things in the User_Autonomous() function, you can put a simple counter inside the slow loop and it will increment once every 26.2 ms. So that's a pretty accurate and simple, if slow, timer.
Timer questions Rick TYler Programming 3 12-02-2006 19:24
Gyro not accurate - Problem naor52 Programming 15 27-01-2006 16:50
Divisions at Atlanta - Accurate Spreadsheet Bharat Nain Championship Event 13 12-04-2004 10:21
timer omega Programming 3 30-03-2004 18:52
