Go to Post A good leader will step down so the right people are in the leadership positions, regardless of age. - Phoenix Spud [more]
Unread 24-01-2007, 18:39
Armando Gonzalez's Avatar
Armando Gonzalez Armando Gonzalez is offline
FRC #1872 (Yellow Fever)
Armando Gonzalez has a spectacular aura aboutArmando Gonzalez has a spectacular aura about
Send a message via MSN to Armando Gonzalez Send a message via Yahoo to Armando Gonzalez
Using the new Gear boxes
Where can I get the keys to attach the new gear boxes (banebots) to our WHEELS?
Armando Gonzalez
Team 1872 - Yellow Fever
San Juan, PR
Awards
Rookie Inspiration Award - 2006 UCF Regional
Last edited by Armando Gonzalez : 24-01-2007 at 18:51. Reason: typed motors instead of wheels
Unread 24-01-2007, 18:42
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
Re: Using the new Gear boxes
the directions to mount them are in the box with the transmissions. the screws on the corners are 2.5 mm and the ones to atach the motor to the plate are 4 mm.
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 24-01-2007, 18:50
sorry i have to rephrase that, how do i connect it to our wheels
Armando Gonzalez
San Juan, PR
Awards
Unread 24-01-2007, 18:56
roborat roborat is offline
roborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to beholdroborat is a splendid one to behold
If you are using the Kit wheels, they have 24 tooth sprockets with them that mount directly to the wheel and then you must mount the 15 tooth sprocket to the transmission shaft using 1/8 keyway to keep from turning and spacers to keep the sprocket in place and run a chain between the two sprocket on the wheel and on the shaft from the transmission.
Unread 24-01-2007, 19:02
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Correct me if I'm wrong, but I don't believe any 1/8" key stock was included in the kit of parts to rotationally lock the sprocket to the keyed shaft of the gearbox. I think this is what you are asking for. I'm not sure what suppliers will ship to you, but in the states, we usually get it from www.mcmaster.com or www.mscdirect.com or at a good local hardware store. Any 1/8" square steel should work with some filing/grinding.
Unread 24-01-2007, 19:10
You are right about not receiving the keyway, the only keyway was to mount the motors to the transmissions. I picked some 1/8 keyway up at Lowes. We are using 1/2 conduit cut to size for spacers.
Gear Boxes team_1373 Motors 4 25-07-2006 00:19
How do you mount the encoders to the Gear boxes? waialua359 Technical Discussion 5 01-02-2006 21:07
pic: gear boxes Kyle A Robot Showcase 18 23-11-2005 18:44
gear boxes BoticsPUNK General Forum 6 24-01-2003 20:35
Gear Boxes Keithicus Technical Discussion 3 21-01-2002 23:22
