Go to Post I always viewed Gracious Professionalism as "I may not agree with you or even like you but we need to work together to solve this problem. So let's get to work!" - Koko Ed [more]
Unread 25-01-2007, 17:21
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Attaching Mini-Bike motor to stock banebot gearboxes!
Hi guys,
How would I attach the mini-bike motors to the stock banebot gearboxes! Any help would be greatly valued.
Unread 25-01-2007, 17:31
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: Attaching Mini-Bike motor to stock banebot gearboxes!
Hello,
IFI sells a Mini-Bike motor mounting kit that could be pretty easily adapted to mount to the Banebots 12:1 gearbox.
after that all you will need to do is fix the Pinion gear to the mini-bike shaft which isn't bad because it is the same size as on the small CIM (which the banebots box is designed to interface with). I recommend either using loctite to fix the gear on or if you are brave cutting a keyway into the shaft and then using a key along with loctite.
we thought about doing this and got as far as keying the pinion to the sahft before we got scared off for weight reasons.
Good luck!
RAZ
Unread 29-01-2007, 17:03
Ted_Z Ted_Z is offline
FRC #1348 (Commanders)
Ted_Z is an unknown quantity at this point
We were able to mate the big CIM to the BB 56mm tranny by doing the following.
- Machined the face of the Big CIM flat leaving a 1" OD X .13" tall boss in order to retain the bearing. I Also removed the "ear".
- Drilled and tapped 4 10-32 holes on a 2" diam bolt hole pattern.
- The output shaft was keyed with a tiny endmill, and trimmed slightly.
The above make the face of the big CIM just like the regular one except that the boss is 1" vs 3/4" OD
- Finally ID of the housing of the gearbox was opened from 3/4" to 1" diam in order to accomidate the larger boss.
-Ted
#1348
JFK HS, Denver, CO
Banebot 2 motor adapter Ben Piecuch Motors 5 17-01-2007 16:06
Mini-bike motor on the bane bots gear box free_rider_151 Technical Discussion 2 12-01-2007 21:17
New Model Posted - Mini Bike Motor Ed Sparks Inventor 0 18-01-2006 23:03
Poll: CIM vs. Bike Motor? Swan217 Motors 18 14-01-2006 13:02
Anyone modifying the stock gearboxes? Swampdude Technical Discussion 17 04-02-2005 13:15
