Where can one purchase the 40 amp maxi fuse blocks, 2007 model?
thank you!!! |
Re: buying 40 amp maxi fuse blocks
http://www.walmart.com/catalog/produ...uct_id=2606832
Something like that? If not try googling some more. ![]() |
The 2007 model is the same as the 2006 and 2004 model. Try Terminal Supply.
Well, you could always search the forums here, as I'm SURE someone else has tried to purchase these before.
Oh, look what I found. BEN |
| Modifying 40 Amp maxi fuse block | kborer22 | Electrical | 18 | 23-01-2007 10:12 |
| Maxi style fuse box | Ken Loyd | Technical Discussion | 4 | 31-01-2006 13:55 |
| Distro block, maxi fuse box, and ground stem | ErichKeane | Electrical | 25 | 20-02-2004 07:19 |
| Maxi 40 Amp Fuse Panel | mtrawls | Electrical | 25 | 13-02-2004 15:19 |
| Reliable Connections to the fuse blocks. | Al Skierkiewicz | Electrical | 0 | 09-02-2004 12:01 |
