Go to Post A mentor, by definition, provides a nuturing environment and, over time, makes themselves progressively unnecessary. - Rich Kressly [more]
Unread 25-01-2007, 22:11
Gratz Gratz is offline
FTC #0537
Gratz is an unknown quantity at this point
Drive Train Size for Ramp
I am working on constructing a ramp for our team and was wondering how far apart many teams have spaced the wheels on their drive trains so we know what we need to accomodate. Thanks.
Unread 25-01-2007, 22:17
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
Re: Drive Train Size for Ramp
My recommendation is to design a ramp with no greater angle than what the ramp was last year. I believe it was 30 degrees. That will probably be a safe bet.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 25-01-2007, 22:40
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Erm... to answer the question posed, I will proceed to consult my Magic 8-Ball.
22" to 28" wide: Most likely
29" to 38" wide: Outlook not so good
39" to 72" wide: Very doubtful
Greater than 72" wide: Better not tell you now
Okay. Aside from the smart alec remark for the last one, the 8-Ball seems pretty reliable. To translate into more useful figures, though, you're likely to see about 75% of teams in the first category, 23% of teams in the second, and 2% of teams in the third. The 4th category is, of course, illegal. So. The Magic 8-Ball has spoken.
Unread 25-01-2007, 22:49
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
I don't think that any team will have a wheel-base greater than 36" or so...
Unread 25-01-2007, 23:15
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Are you asking this question:
http://www.chiefdelphi.com/forums/sh...ad.php?t=52413
or are you asking about wheelbase? ie front to back wheel spacing
Unread 26-01-2007, 00:21
kibbs425 kibbs425 is offline
AKA: Kyle Henry
FRC #0125 (Nutrons)
kibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to beholdkibbs425 is a splendid one to behold
Send a message via AIM to kibbs425
My opinion... if you can afford it don't leave it up the other team to have a configuration to match your robot, design your robot to match any configuration, i.e. someone very well could have a kiwi or something similar and thats not going to work with a set wheel path to get up.
That said. Physically, probably not larger than 38 in. wide and you could probably count on the middle 12-15 in. not being used too much but the more you can give them for a trak the less you ahve to rely on the other drive to precisely drive it up. Probably going to be some mad dashes for the ramp.
Also if you cam make it shallower than 30 deg. that would be better but I know we are personally planning on at 30 deg max ramp. Not wat we want to go up but the robot can do it if we have to.
Since 2002
Unread 26-01-2007, 00:45
MrForbes's Avatar
AKA: Jim
Wheelbase is generally the measurement between axles in the direction the wheels roll. Track width is generally how wide the wheels are spaced between sides, either center to center or overall width across both wheels.
I doubt we'll see any robots with a wheelbase longer than 34", but we could see some with track widths near 38"
Unread 26-01-2007, 00:57
Cody Carey's Avatar
AKA: C. Carey
FRC #0306 (CRT)
Originally Posted by Lil' Lavery View Post
The wider starting dimension is 38", so it's very possible many teams will be right at 37-38" (exposed wheels).
True, and I took that into account when saying that I don't believe any will.
Since, according to the earlier poll on the subject, only 16% of robots will be running a "wide" base, I don't believe we'll see very many, if any, cantilevered wide drives. You can just call it a hunch.
'lil Lavery was right in that you should design for a 38 incher anyway... just in case.
We'll just have to wait and see if my hunch is correct.
Unread 26-01-2007, 18:57
FTC #0537
I actually meant track width--thank you for correcting me and also redirecting me to that other poll.
Motor mount assembly for drive train? jdejoannis Kit & Additional Hardware 2 20-01-2007 14:09
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive-train shaft size Andrew Schuetze Technical Discussion 27 27-07-2005 15:41
[ECDU]: Right drive train for this game Michael Leicht FIRST-related Organizations 4 03-04-2005 22:31
Choosing an Encoder for the Drive-train MikeDubreuil Electrical 11 21-10-2004 00:50
