Go to Post When was the last time you heard of someone on their death bed talking about a great movie they saw? I think it far more likely to hear of their accomplishments, something they did to make things better. Well that's what FIRST is all about. - DougHogg [more]
Unread 26-01-2007, 21:07
BQuennell's Avatar
BQuennell BQuennell is offline
Electronics Mentor
FRC #1388 (Eagle Robotics)
BQuennell has a spectacular aura aboutBQuennell has a spectacular aura about
Send a message via AIM to BQuennell Send a message via MSN to BQuennell
Fuses for solenoids
Hey, I've been looking through the pneumatics manual and it doesnt refrence to if I need a 20 or a 30 amp fuse for it from the circuit breaker panel. Also is it the same for the compressor, its our teams first year trying pneumatics so I'd like it to work without us burning stuff out.
Eagle Robotics Team 1388
It's Hammertime!
2005 SAC Engineering Inspiration Award
2006 SAC J&J Sportsmanship Award
2007 LA Xerox Creativity Award
2008 SD Xerox Creativity Award
2008 SAC Regional Finalist
2008 SAC Engineering Inspiration
Unread 26-01-2007, 21:10
Re: Fuses for solenoids
Compressor spike may use a 20 amp breaker instead of the fuse on the spike. Not sure what the breakers are for the rest of the system. Have you checked Section 8 of the manual? There may be something there, but I just gave it a quick read in the relevant area and didn't see anything. You might want to read it carefully--it's around page 26.
Unread 26-01-2007, 21:40
Electrical Engineer
Rookie Year: 1995
You need 20A breakers feeding each of the spikes. Note that you need this even though each spike has a fuse built in. You have to provide CB protection at the source (breaker panel).
The output of the spikes are connected to the compressor and the pneumatic solenoids (read the manual/directions and be sure that you replace the 24V coils of the SMC solenoids with the 12V coils).
The 20A fuse on the spike feeding the compressor may be replaced with a 20A circuit breaker (note that this is the only Spike that you can do this to).
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 26-01-2007, 22:14
DonRotolo's Avatar
Back to humble
FRC #0832
To summarize:
Feed Spikes with a 20A breaker (one per spike) from the Circuit Breaker Panel.
Fuse in Spike must be 20A
ONLY the compressor spike can use a 20A breaker instead of a fuse.
Don
OI Fuses? The Lucas Control System 4 09-02-2004 22:48
20 amp fuses for Spikes Andrew Schuetze Electrical 8 01-04-2003 22:18
Fuses for Robot CONTrol archiver 2001 0 24-06-2002 01:02
FUSES FOR ROBOT CONTROL archiver 2001 4 24-06-2002 01:01
Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? Anton Abaya Chit-Chat 4 12-01-2002 14:09
