Go to Post I was cheering like mad during the last match on Einstein - I think the rest of my team thought I was crazy...or crazier than they thought I was before! - Sean Schuff [more]
Unread 30-01-2007, 22:24
Priyadarshy's Avatar
Priyadarshy Priyadarshy is offline
FRC #0612
Team Role: Mascot
Priyadarshy has a spectacular aura aboutPriyadarshy has a spectacular aura about
Send a message via AIM to Priyadarshy
pic: 612 Drive System
Unread 30-01-2007, 22:27
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is online now
FRC #2363
Re: pic: 612 Drive System
Looks like the wheels on the closest side are up off the ground a bit. How much does the 'bot wobble?
Looks good, otherwise. Nice wheels. Messy electronics.
What's bolted on top? A polycarb sheet?
Unread 30-01-2007, 22:35
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I believe that the center wheels are lowered 1/4", so the bot has a fair bit of rock.
Unread 30-01-2007, 23:19
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
They don't really wobble at all as of now. Thats because of the battery....but again, its not done. Arm still have to mounted so we might be changing the position of wheels.
Electronics are really not messy; but when they are mixed with pnuematics, i think it just looks like it.
Top is just a piece of wood right now.........don't ask why :-p
Unread 31-01-2007, 01:58
FRC #2363
Originally Posted by Lil' Lavery View Post
...so the bot has a fair bit of rock.
Originally Posted by RoboMadi View Post
They don't really wobble at all as of now...
Woah! Conflicting answers! It'll rock a lot less on the carpet.
Once the weight is more finalized, you should beef up the hardware at the corners of the chassis a bit.
Unread 31-01-2007, 07:07
RoboMadi's Avatar
AKA: Imad
FRC #0612
LOL..... only if Sean is dedicated enough to stay after school
I agree. As of now we are also facing problems with the position of the wheels. But as I said before, we will keep making adjustments as we add weight to it.
Imad
Unread 31-01-2007, 07:34
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
it is currently a 1/8th inch offset it seems to be running better this way now. Before we found the 1/4th inch offset a little bit to much.
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
Unread 31-01-2007, 15:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Or went to Chantilly....
But my statement is true. It has a fair bit of rock, it just never uses it because of the current weight distribution.
Unread 31-01-2007, 18:09
FRC #0612
Team Role: Mascot
yeah we are going to have to make it rock properly it should soon, the whole drive base is 60lbs
2008 NASA/VCU Team Spirit Award
2007 Chesapeake Finalists
2007 Chesapeake Entrepreneurship Award
2007 NASA/VCU Chairman's Award
2007 NASA/VCU Semi-Finalists
2006 Chesapeake Chairman's Award
2006 Chesapeake Woodie Flower's Award
2006 NASA/VCU Engineering Inspiration Award
Unread 31-01-2007, 10:18
NoSkaOnTheRadio's Avatar
NoSkaOnTheRadio NoSkaOnTheRadio is offline
Team 1757 Alumnus
AKA: James Carney
FRC #1757 (The Big Green)
NoSkaOnTheRadio has a spectacular aura aboutNoSkaOnTheRadio has a spectacular aura about
Send a message via AIM to NoSkaOnTheRadio
Team 1757 built a robot last year using wood as our primary construction material. It actually held up very well in competition (pretty rough, as anyone who was at the Boston regional can attest!), as wood has a pretty convenient elasticity. Parts of the bot did splinter and crack constantly, but it wasn't hard to "machine" new ones . No shame in going natural!
How tall does the drivetrain stand at the time of the picture, without the arm or the other peripherals?
Unread 31-01-2007, 10:59
RoboMadi's Avatar
AKA: Imad
FRC #0612
Its only 1ft or 12 inches as of now. With arm, it will be 4 ft or 48 inches.
Imad
Unread 31-01-2007, 07:45
AKA: Shan Rammah
you'll find out at VCU
Unread 31-01-2007, 07:48
ChrisMcK2186's Avatar
ChrisMcK2186 ChrisMcK2186 is offline
Typer of doom
AKA: Chris McKenzie
FRC #2186 (Westfield Robotics)
ChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of lightChrisMcK2186 is a glorious beacon of light
Send a message via AIM to ChrisMcK2186
That my friend is the finest of all woods, lighter and more flammable than the competition.
Chris
Working on Robotic Eagles group(PM for info)
Stephen Colbert-"Please tell me this leads to robot
battles."
Dean Kamen-"It does lead to kids building robots, and they do compete in the sport but we also teach the kids gracious proffesionalism, so while the robots are competing, they do it in a very, very gracious way."
Darn, I got into this for the battles!
Unread 31-01-2007, 09:35
FRC #0612
Team Role: Mascot
yeah we raised up the middle wheel to 1/4 inch offset so it should be better right now, ill post pictures of the wheel assembly sometime
pic: 612 New Drive System Priyadarshy Extra Discussion 4 20-01-2007 23:21
pic: rookie drive system psycho7 Robot Showcase 13 13-03-2006 10:29
pic: Team 612 Drive System RoboMadi Robot Showcase 7 08-02-2006 16:38
pic: SimSwerve Omnidirectional Drive System CD47-Bot Robot Showcase 6 12-06-2004 14:09
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
