Go to Post The Chairman's award is about doing what you can to strengthen the FIRST community. It doesn't require money to simply lend tools, wise advice or a hand. - Koko Ed [more]
Unread 31-01-2007, 02:14
987HighRoller's Avatar
987HighRoller 987HighRoller is offline
Vegas....Baby
AKA: Alex Sambvani
FRC #0987 (High Rollers)
987HighRoller has a spectacular aura about987HighRoller has a spectacular aura about
Linear Control
I was wondering if anybody could give me a good source for a linear potentiometer. I am planning on controlling a pivot point on our robot by using some sort of device that measures linear motion. It doesn't necessarily have to be a linear potentiometer. I know I saw some teams last year with a lever-type device on their control board that measured linear movement to control shooter speed or something... Can anyone point me in the right direction as to where to buy something like this?
Thanks a lot.
Team 987 - The High Rollers - Las Vegas, Nevada
2007 Las Vegas Regional Finalists
2007 Newton Champions
2007 Championship Winners! Thanks to 190 and 177
2008 IRI CHAMPS with 67 and 330
Unread 31-01-2007, 02:43
dtengineering's Avatar
AKA: Jason Brett
Re: Linear Control
Try searching www.digikey.com for "slide".
I think they only come in up to 45mm slides, but other on-line electronics shops might have wider selection. We managed to find some a bit longer at a little store called "Lee's" here in Vancouver http://www.leeselectronic.com/
Just remember that you probably want the linear taper rather than the audio taper.
Good luck,
Jason
Linear slides Andrew Schuetze Kit & Additional Hardware 10 18-01-2008 23:37
80/20 linear motion? Nitroxextreme Technical Discussion 15 22-01-2007 09:55
Linear Potentiometer FRC1710 Motors 4 15-01-2007 19:20
Linear Actuator NoRemorse General Forum 4 17-01-2004 21:02
Linear slides Gui Cavalcanti Technical Discussion 4 02-01-2004 15:59
