Go to Post Nobody wins a Regional on Thursday. - Bill Moore [more]
Unread 31-01-2007, 10:55
SoD SoD is offline
FRC #2230
SoD is an unknown quantity at this point
PWM, victors and motors
We need to get the Fisher-Price 9012 motor to work... but the problem is that we can't give him more than 40 Amps... which meens we need to control the PWM values in a way that the victor won't give more than 40 Amps... meening somewhere between 255 and 127. But how can we know the exact value?
Unread 31-01-2007, 11:05
Electrical Engineer
Rookie Year: 1995
Re: PWM, victors and motors
Sod,
You can give the motor more than 40A. The Victors (PWM control) regulate the voltage to the motor. The current is a factor of the voltage provided and the mechanical load on the FP.
I would start by reading some of the presentations on motors in the white papers section of this forum (anything written by Joe Johnson is great).
Next, I would search these forums on how a circuit breaker works and how you can deliver more than 40A to a motor.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 31-01-2007, 11:06
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
I'm sure someone else can provide a detailed answer, but I'll give a quick one.
When you set a PWM output from 0 to 255 you are not setting voltage or current What you're actually setting is the duty cycle output of the Victor to the motor. Duty cycle is a percentage and the rough equation is (On Time)/(Off Time).
Examples:
  • PWM Value: 127
    Duty Cycle: 0 %
  • PWM Value: 255
    Duty Cycle: 100% (Normal polarity)
  • PWM Value: 0
    Duty Cyle: 100% (Reverse polarity)
The current a motor draws is related to the amount of power required to turn the output shaft. The more friction in the mechanism the higher the current draw will be. This is a mechanical issue not a programming issue.
Unread 31-01-2007, 12:24
Chaychay Chaychay is offline
AKA: Jay Shah
FRC #0610 (Crescent Robotics)
Chaychay is on a distinguished road
Send a message via MSN to Chaychay
A couple years back FIRST provided current sensors in the kit. If you put one of these on your Fisher Price Motor circuit, you could just tone down your PWM output as the sensor output got closer to 40 amps. (Like a proportional controller)
EDIT: I just read the posts above mine, and they render my post incorrect. But just for your reference, you can stick a current sensor on their to monitor how much you are drawing.
"Backdriving" Motors -- Safe for Victors? Ken Streeter Electrical 6 20-01-2007 14:02
victors spikes and pwm cables sburro Electrical 3 23-02-2005 02:24
Motors and Victors/Spikes anna~marie Electrical 4 01-10-2004 21:58
PWM Cable Clip for Victors sanddrag Technical Discussion 9 18-07-2004 19:27
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
