Go to Post I can't help looking at the new center piece my wife put on the dinning room table and think to myself, "non-functional decoration" - DarrinMunter [more]
Unread 31-01-2007, 20:06
G-Ball's Avatar
G-Ball G-Ball is offline
FRC #2178 (Riobotics)
Team Role: Student
G-Ball is an unknown quantity at this point
Intertube inflation?
Ive heard rumors from different teams that the tubes are not fully inflated. Are the tubes supposed to be fully inflated and if not how much should they be?
Unread 31-01-2007, 20:11
Billfred's Avatar
Billfred Billfred is offline
Re: Intertube inflation?
Rumors are just that, rumors. FIRST will be inflating the inner tubes to a specified size, plus or minus a bit, according to Section 6.3 of the manual:
6.3GAME PIECES
The GAME PIECES are toroidal tubes made of inflatable plastic. When inflated, each GAME
PIECE is approximately 32 inches across the outer diameter. Each toroid has an inner diameter of
approximately 13 inches, and a height of approximately 9-1/2 inches. There are three types of
GAME PIECES used in the game.
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
never mind - Billfred beat me to it!
Unread 31-01-2007, 20:15
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
Our team, as well as several others asked this question on the FIRST Q&A, here were some of the responses from the GDC:
Originally Posted by GDC
When measured in geologic time, it is virtually certain that gas exchange at a molecular level will occur across a semi-permiable membrane. Therefore, you can anticipate that the pressure within the tubes will change over time.
There are very clearly stated standards for the Game Pieces. Section 6.3 of the manual declares that when inflated the Game Pieces are approximately 32 inches across the outer diameter and approximately 9-1/2 inches tall, with an inner diameter of approximately 13 inches.
During the competition all Game Pieces will be inflated to their approximate size, not to a specific pressure. Individual Game Pieces will be replaced as necessary if they are unable to hold sufficient pressure to maintain the size requirement. As previously noted, the pressure within each individual Game Piece can be expected to vary over time should damage, small leaks, or normal wear and tear occur.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 31-01-2007, 21:05
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
What happened to the 2PSI thing that I read about I believe in the manual?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 07-02-2007, 22:53
Dr.Bot
Posts: n/a
AT the FTA training the proper care and feeding of tubes was discussed. Each field is shipped with four ac powered inflaters and a custom made 'fill' tube. They also ship a plywood fixture for 'sizing' the tube. The idea is to inflate the tube until it is just 'snug' in the fixture. The fixture looks like the letter 'U.'
Bottom line is there will be some variation in the inflation pressure - so deal with it.
Unread 09-02-2007, 13:48
Justin M. Justin M. is offline
Mechanical/Driver
FRC #0321 (RoboLancers)
Justin M. is on a distinguished road
Send a message via AIM to Justin M.
You should expect the tubes to be anywhere from fully inflated to completely deflated, they will be still considered live, scorable pieces in pretty much ANY state of inflation.
Team 321: CHS RoboLancers - Drexel University, CHS Alumni Assn., SDP, Philadelphia Motorsports, Lima Corperation
Small ball inflation problem Mike8519 General Forum 9 06-03-2004 05:33
game ball inflation archiver 2000 5 23-06-2002 22:28
