using servos with camera
how do you add servos to the camera....and also when the robot gets to the light how can you make the robot stop
Re: using servos with camera
Read this document: http://www.chiefdelphi.com/forums/at...3&d=1168964099
You should be able to move your robot with the camera by the end. |
if (TILT_SERVO > 190)
LEFT_DRIVE = 127;
RIGHT_DRIVE = 127;
| Camera without servos | kiettyyyy | Programming | 17 | 10-04-2006 21:45 |
| problems using gyro/adc code with camera default code | tanstaafl | Programming | 7 | 22-01-2006 23:09 |
| servos and the camera | incognito_NICK | Programming | 5 | 09-02-2005 00:00 |
| Servos for the camera | MV_Hirsch | Programming | 4 | 24-01-2005 16:35 |
| using older servos | pryoplasm | Kit & Additional Hardware | 4 | 24-01-2004 20:22 |
