adding second camera
hi, quick question for you electrical people...hopefully your the right people to ask. is there anyway to hook up a second camera to the RC? I am trying to use the camera from 2006 along with the camera from this year. is there any way i can hook this up? thanks
-iwdu15 --team 811 |
Re: adding second camera
Use the program port on the RC to communicate to the second camera over RS232 not using TTL, get kevin watson's serial ports code to talk over that serial port.
There are a few different ways of communicating to the camera over a serial port, i suggest starting with kevin watson's documentation and then move to the two camera code posted by FIRST (as a reference on protocol format). This will be difficult to debug, so you might consider using the user byte format which is sent to the OI. You can use the dashboard (available from IFI ) to read the user byte format. |
| Adding Code | haywirerobotics | Programming | 2 | 18-01-2006 07:04 |
| second camera | sj31419 | Programming | 7 | 20-01-2005 18:19 |
| Adding objects | Matthew_H | 3D Animation and Competition | 5 | 12-02-2004 19:33 |
| Adding RAM to RC | archiver | 2001 | 1 | 24-06-2002 00:59 |
| Adding my Thanks | archiver | 2000 | 0 | 23-06-2002 22:57 |
