Go to Post It's a bird! It's a plane! It's SUPER-TUBE! - dlavery [more]
Unread 01-02-2007, 21:33
b_mallerd b_mallerd is offline
Programmer
FRC #1346 (Trobotics)
b_mallerd is on a distinguished road
Send a message via MSN to b_mallerd
Mecanum Feedback
Hey,
This is 1346's first time using mecanum wheels and we're having some difficulty with the controls.
We have the vector addition equations and everything but currently working on a closed loop system using optical encoders. Is this the best way of going about it?
For those of you who have built mecanum drive trains before: What is the best way to "close the loop" and get feed back?
Gyro? Encoders? Other techniques?
Any comments on the programming is also highly appreciated cuz I am the programmer after all...
Unread 01-02-2007, 21:59
Umm Errr...
Re: Mecanum Feedback
Out of curiosity does it behave at all without feedback?
1139 Alumni
Unread 01-02-2007, 22:00
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Actually assuming you have the equations working properly, that's the trickiest part. Encoders will give you the speed of each wheel which is what you need to control fwd/back/strafe etc. For twist you need a gyro. Now implement a simple proportional control loop for each wheel and it should drive like a charm.
Unread 02-02-2007, 18:23
Jared Russell's Avatar
Taking a year (mostly) off
Most holonomic drives don't behave AT ALL without some sort of feedback. Although sometimes if you just use a gyro (without encoders) and some clever programming, you can get by.
Unread 02-02-2007, 22:07
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
I'm sort of at the same point with my code.
We are working on the mecanums. I'm using a combo of the optical encoders made for banebots gear boxes and the gyro. Not too sure how it's going to turn out. I'm writing code now, I'll test it tomorrow. I'd be happy to share when I figure it out.
Jacob
Unread 03-02-2007, 02:19
Programmer
Hey,
The drive train isn't usable without any feedback. When commanded to drive straight, it moves in a kind of arc and I bet if the floor is big enough it'd do a perfect circle (probably motor bias).
Recently we broke an encoder so it'll be a few days until the new one ships in but in the meantime I can always to figure out how to implement the gyro.
Great advice, Thanks.
mecanum programming mrmummert Programming 27 28-01-2007 13:45
Mecanum Suspension? thefro526 Technical Discussion 4 09-01-2007 23:09
Mecanum Rob2713g Technical Discussion 13 03-11-2006 14:16
Mecanum Wheels TheFerret Technical Discussion 8 16-01-2006 09:23
