Go to Post if your robot weighs 1-1/2 tons, you have bigger problems then the legality of that jack... - ekapalka [more]
Unread 03-02-2007, 11:49
Lakeeffect1674 Lakeeffect1674 is offline
FRC #1674
Lakeeffect1674 is an unknown quantity at this point
Camera No Data
We have the camera set up just like last year (and it was working) our connections are believed to be tight but we still get the error " no camera data" what can we do to fix it?
Unread 03-02-2007, 12:31
RedHeadRobotics's Avatar
RedHeadRobotics RedHeadRobotics is offline
AKA: Brigid
FRC #2081 (Icarus)
RedHeadRobotics will become famous soon enoughRedHeadRobotics will become famous soon enough
Re: Camera No Data
Well, our programmers are having the same problems with our camera. There are some definite issues with the default camera software. We are still having mentors weed throught the software to see what the problem is.
Unread 03-02-2007, 12:32
AKA: Brigid
FRC #2081 (Icarus)
Re: Camera No Data
Keep at it, it seems hard, but it's not impossible
Unread 03-02-2007, 13:49
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
Re: Camera No Data
We had a problem with making sure the connections were all matched, the black conductor with the B letter. We also didn't have the TTL chip flush in the correct orientation, and it caused the same problem.
Unread 04-02-2007, 11:45
FRC #1674
Re: Camera No Data
We made sure we had the connections right, several times. We are thinking now that we should just disable the camera so we can atleast test the robot.
there are several ways I was thinking we could do it.
1. add code to feed the controller data and claim it is camera data
2. clear everything about the cam in the code (really hard to do)
3. maybe we could even comment out a part in the cam code to disable it
Any of these ways I am not sure on how to do it. which way do any of you think would be best and how would we go about doing it.
Unread 04-02-2007, 12:19
fallen751 fallen751 is offline
FRC #2052
fallen751 is an unknown quantity at this point
Re: Camera No Data
you should check which serial port is enabled for camera communication, it might not be the same one you are plugging in to. I believe the default port is the TTL or serial_port_2. Also, kevin's code comments out the default routine, which you might want to enable to drive around. Make sure that you are getting both green and red light on top of the camera. Makes sure the camera switch is turned on. keep working at it!
trasmitting data from a second camera iwdu15 Programming 1 02-02-2007 19:25
Question about default camera data table in easyC pro itsme Programming 1 16-01-2007 13:57
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
Distribution of data soap108 Scouting 4 24-12-2001 09:23
