Go to Post The world isn't changed by people playing it safe. - Andrew Y. [more]
Unread 03-02-2007, 21:50
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Problems with tether
We noticed tonight that while on tether, the OI is not receiving any data from the RC. The dashbord program does not display any data from RC. When we connect the radio modems, everything seems to work fine. If we replace the 2007 RC with a 2005 RC every thing works correctly on tether. Has anyone else had problems with their RC on tether?
I realize that some people have had problems with the radio modems. I read quite a lot about that issue while searching to see if anyone had information about this problem.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 03-02-2007, 22:30
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
Re: Problems with tether
have you tried a different tether cable? if that dosent work i would contact IFI.
/forest
Unread 03-02-2007, 22:37
/forest
Yes, We have tried two different tether cables and both work on the 2005 RC. This problem only exists in our 2007 RC.
I have emailed IFI.
Unread 13-02-2007, 17:22
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
We had this problem two years in a row (2006 and this year).
In both cases, it was a confirmed problem with our RC (2006 was reportedly bad caps on the tether port, this year was a "bad connection" on the tether port).
If you have tried multiple tether cables, I highly recommend you contact (phone) IFI for an RMA.
Problems with a video! JakeGallagher IT / Communications 11 15-04-2005 23:36
problems with G22 JMH Electrical 2 19-01-2005 20:52
Problems with MPLAB Charley Programming 20 25-02-2004 18:13
PROBLEMS WITH AMP's!!!!!!!!!!!!!!!!!! Tton Electrical 2 14-02-2003 07:54
Problems with Titiles Kyle Fenton CD Forum Support 0 29-01-2002 14:20
