Go to Post You can't stop trying to look for other ways to do things, or that really defeats the whole purpose of inovation. - AmoryG [more]
Unread 04-02-2007, 15:26
LionMane250's Avatar
LionMane250 LionMane250 is offline
User
AKA: Cooper
FRC #0250 (The Dynamos)
Team Role: Driver
LionMane250 is an unknown quantity at this point
Ramp Materials
This is for those of you who are making & designing a robot with a ramp. What are you making it out of? What problems are you having with deploying the ramp with an arm? Without an arm?
Unread 04-02-2007, 15:51
MarsBOtkid MarsBOtkid is offline
FRC #1523
MarsBOtkid has a spectacular aura aboutMarsBOtkid has a spectacular aura aboutMarsBOtkid has a spectacular aura about
Post Re: Ramp Materials
Aluminum with some type of gripping device on top
Unread 04-02-2007, 17:12
burkechrs1 burkechrs1 is offline
AKA: Chris
FRC #0668 (The Apes of Wrath)
Team Role: Driver
burkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to allburkechrs1 is a name known to all
Send a message via AIM to burkechrs1
Re: Ramp Materials
carbon fiber panels. very lightweight and very strong. then we're putting a grippingmaterial over them for obvious reasons...
Unread 06-02-2007, 21:09
Po-ser's Avatar
Po-ser Po-ser is offline
AKA: Polina Danilyuk
FRC #0694 (Stuypulse)
Po-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud ofPo-ser has much to be proud of
Send a message via AIM to Po-ser
Re: Ramp Materials
We're using carbon fiber for our ramps too--thin sheets with foam blocks sandwiched inbetween. We're only at the point where we're just about to mount them, though, and we're trying to figure out how many spares we'll need. Have you guys been playing around, seeing how much it takes to break them? It would be awesome to have some input.
And Matt Gardner, as for a suggestion for your team--like the others, I'd strongly consider using honeycomb (try going to mcmaster.com and type in "Aluminum Honecomb" into the search tab). It's not cheap, but it's very light for its strength (good enough to be used for floor panels in airplanes). There's also the added benefit of spending less time constructing the actual ramp, since it arrives at your lab all in one piece, and spending more time on the actuators.
Hope this helps.
Aim for the stars, land in Hawaii.
2003 - NYC Regional winner
2005 - NYC Regional Woodie Flowers Award
NYC Regional Chairman's Award
Championship Galileo Division semifinalist
Unread 06-02-2007, 23:30
Uncrash's Avatar
Uncrash Uncrash is offline
The People's Hero
AKA: Jake Augunas
FRC #1276 (Kaizen Blitz)
Team Role: Communications
Uncrash is an unknown quantity at this point
Re: Ramp Materials
My first response would be to say aluminum angle and lexan, with cross supports underneath.
However, everyone is suggesting these new-fangled sandwiched materials. I'd suggest going with these, as I think thats what our ramp is being made from.
I'm pretty sure we got a few of our crew to go pillage the space shuttle, because whatever we found is some crazy stuff...
2006 - BAE Granite State Regional Champions
2006 - BAE Granite State Regional Team Spirit Award
Mathematics is the language of the universe.
The Written Word is the language of the people.
Learn both and you will be wise beyond compare.
Unread 07-02-2007, 08:57
AChastain's Avatar
AChastain AChastain is offline
FRC #0234 (Cyber Blue)
AChastain will become famous soon enoughAChastain will become famous soon enough
Re: Ramp Materials
I would look into corrugated plastic if...when weight becomes an issue. As long as you provide some support around it's edges to prevent bending, it has potential to work.
"Thirty bucks says the blue guy wins."
"You On!"
- bystanders, MEGAS XLR
Unread 07-02-2007, 09:36
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: Ramp Materials
Welded steel mesh from the ramp used in Stack Attack of 2003 on an aluminum frame. 27 inches wide, almost 10 feet long, ~23lbs
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 07-02-2007, 21:07
S-man's Avatar
S-man S-man is offline
Pyscho Robotics Guy
AKA: S-Man
S-man is an unknown quantity at this point
Re: Ramp Materials
Aluminum & stuffff....
COLOR="Red"]
Hate, Hate, Hate, Double Hate, Loathe ENTIRELY
[/color]
If you utter as much as one syllable I will hunt you down and gut you like a fish! if you'd like to fax me press the star key.
Unread 07-02-2007, 23:08
Matt Gardner's Avatar
Matt Gardner Matt Gardner is offline
...shiny.
AKA: Basil Mook~Sang
FRC #2200 (MM Rambotics)
Matt Gardner is an unknown quantity at this point
Exclamation Re: Ramp Materials
Our team is now looking at Alumalite as a viable option (thanks Dad1279!). Does anyone know a local distributor of Alumalite? We are in Burlington, Ontario (In the Greater Toronto Area). We need at least 4'x10' sheet perferably in black/pink, but we'll buy whatever is cheap and available. We'd like to be able to pick it up Thursday if its close enough, because we don't have enough time really to have it shipped in...
Also, Dad1279, or someone from his team, or anyone who's dealt with alumalite...Do you know the mass per square foot of Alumalite? And is it really strong enough to support robots (with a proper frame, of course)?
Thanks again everyone, you've all been a great help...
---------------------matthew gardner--------------------------------------------------------------------
| Catapultam habeo. Nisi pecuniam omnem mihi dabris, ad caput tuum saxum immane mittam |
FIRST, Breathe. FIRST, Breathe. FIRST, Breathe. FIRST, FIRST. Crap.
Unread 07-02-2007, 23:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Ramp Materials
what is "Alumanite"?
never heard of it....google doesn't seem to know much about it....
Unread 07-02-2007, 23:17
...shiny.
Re: Ramp Materials
look on page one, there's a link somewhere...oh, and sory, I mispelled it a couple times its actually Alumalite
Unread 08-02-2007, 12:03
Jetgrindradio00's Avatar
Jetgrindradio00 Jetgrindradio00 is offline
Jesse Laufer
AKA: Jesse
FRC #0580 (Campbell Hall Vikings)
Jetgrindradio00 will become famous soon enoughJetgrindradio00 will become famous soon enough
Re: Ramp Materials
We are using 3/4th aluminum square tubing, aluminum L-bracket, and steel mesh for the top....works well. Pics/Vid will be released in the near future (as soon as i remember to bring my camera to a meeting ).
Formerly a member of oakwood school 992, but traded to champbell hall 580 .
2007 Los Angeles Regional Finalists (thanks 980 and 696)
Unread 04-02-2007, 17:54
MrForbes's Avatar
AKA: Jim
Re: Ramp Materials
We're planning on building the gripping material into the aluminum ramp....using a secret patented process.....
Unread 04-02-2007, 18:06
wingnut1705's Avatar
wingnut1705 wingnut1705 is offline
AKA: Kevin
FRC #0453 (Gears)
wingnut1705 is an unknown quantity at this point
Send a message via AIM to wingnut1705
Re: Ramp Materials
Our team is using panels that are a composite of aluminum, plastic and styrofoam. It holds up very well.
Unread 04-02-2007, 20:28
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: Ramp Materials
Aluminum extrusion frame (8020) and 8020 honeycomb paneling thats 1/8" thick (its just like cardboard but plastic)...and it is extremely light weight.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Motor Ramp Up/Ramp Down Function Tom Bottiglieri Programming 12 03-12-2006 23:31
To ramp, or not to ramp? phrontist Rules/Strategy 27 26-01-2006 17:56
Materials stinger 3D Animation and Competition 3 26-02-2005 17:47
Materials Jeff K. General Forum 11 22-01-2005 02:24
Materials Finch Rules/Strategy 2 28-01-2002 23:00
